LED JVC LT-40N530A half screen black.
  • MegaZAC
    • Oct 2020
    • 49
    Main:
    tp.sis231.p83
    T-con
    KSZ80_OB_S4LV0.2
    E88441
    T-con has:
    rt6503a
    bm81204 317 h56
    AMLCD LQF6041T0B-01
    First, it had stripes on the right side. Pushing the top corner changed them, but not removed. I disassembled the TV, and since that all that side is black without stripes.
    I checked a lot of suspicious things. Found that no matter where I push there will be no stripes anyway. Seems, there are different issues.
    Found dodgy voltage INV_V randomly jumping from 1.4 to 1.8V on T-con. But I also not sure that the main board is fine.
    Also, on the problem side of T-con there is no negative 7.5 volts, not sure it by design or a bug.
    Any ideas?
  • MegaZAC
    • Oct 2020
    • 49
    Re: LED JVC LT-40N530A half screen black.
    Still no ideas?
      Show us the screen shots of what the image looks like on the screen.
      • MegaZAC
        • Oct 2020
        • 49
        • Diah
          • Feb 2013
          • 6564
          since you had the tv disassembled. its much like you damaged one of the LCD glass corner which always had VCC thin film line .. go back and inspect the end glass of the LCD
          • MegaZAC
            • Oct 2020
            • 49
            All corners are perfect. From outside the whole panel has no damage at all.
              • 12330
              • U.S.
              Looks like you have been pretty thorough, did you check the little ceramic caps on that driver board for shorts or low ohms? I would be suspicious of any reading less than 100 ohms.
              • MegaZAC
                • Oct 2020
                • 49
                There are no shorts anywhere on both boards, checked by multimeter + thermometer. However, it may be inside the panel.
                Ceramic caps have low capacity, but that seems normal for em. The biggest show open wire, medium show 20-60 kOhms, and the lowest measured value is 560 Ohm on the 102 1kv capacitor following the main inductor. Not sure that this is a proper value, but I would expect different issues if this one would be the root problem.
                • Diah
                  • Feb 2013
                  • 6564
                  could you please upload photos on the LVDS socket at main boards and the area around from both side,, there should be R or F1 for VCC
                    https://www.badcaps.net/forum/attach...9&d=1601724264
                    Can you show us the whole length of the board and also the pictures of the whole backside of the TV showing all the boards?
                    • MegaZAC
                      • Oct 2020
                      • 49
                      LVDS is 40-pin, unplugged for better view. Not sure about R or F1.
                      • Diah
                        • Feb 2013
                        • 6564
                        this is JVC TV !!! its Chinese DIY TV LOL
                        you need to take out the LVDS complete out from this DIY and sitting at comfort place and start with yours DM Beep Ton to test all pins from MB side to the end of ribbon cable which it goes to the panel socket.
                        • MegaZAC
                          • Oct 2020
                          • 49
                          T-con in good res
                          https://freeimage.host/i/26oVMx
                          https://freeimage.host/i/26oW6Q
                          • MegaZAC
                            • Oct 2020
                            • 49
                            Done, all pins work fine.
                            • Diah
                              • Feb 2013
                              • 6564
                              for me i am sorry.. out of any idea for this Chinese DIY
                              the only things i do know.. they sell this All IN ONE DIY TV boards on web
                                • 12330
                                • U.S.
                                Maybe try hitting all the boards driver board included with a hairdryer, warm it up kind of toasty and see if there's any difference on display.
                                  https://www.badcaps.net/forum/attach...0&d=1601724264
                                  Did you check the resistance of those MLCC (Multi Layer Ceramic cap) in that section to see if any of them show low resistance reading, I.E. <100 Ohms?
                                  • MegaZAC
                                    • Oct 2020
                                    • 49
                                    Checked all, found 3 groups below 100 Ohms. From left to right:
                                    1) 0 Ohm, both signed as test
                                    2) 44-45 Ohm each.
                                    3) 10 Ohm each.
                                    There is nothing like a single broken one. Either whole group is broken, or fine.
                                      • 12330
                                      • U.S.
                                      Measure just the capacitors, skip the resistors for now, the caps have a C by them on the board.
                                        2) 44-45 Ohm each.
                                        3) 10 Ohm each.
                                        You tested the wrong the parts.
                                        C = Capacitor
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Demonith
                                          Adler-43ae99s Plz help me fix it ! half black screen
                                          by Demonith
                                          Hi i am not expert on fixing i am learning just to make shore about but every help is welcome so i have here Adler-43ae99s and what i done is replace the bad capacitors on mainboard and backlights now what i have problem is its all black no image no sound so i have try testing it on RCON flat cables when i remove LEFT its black and white but when i remove RIGHT its all black now i am on dead end here and i am feel let down on my self with this one i hope some one will help
                                          02-10-2025, 12:12 PM
