Vizio D55-f2 backlight/power supply 20v/24v rail output high 26v
  • diif
    • Feb 2014
    • 6978
    • England
    #41
    Re: Vizio D55-f2 backlight/power supply 20v/24v rail output high 26v
    The three makers R_J references all have different size fuses, you should be able to determine the maker with a micrometer.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      #42
      Originally posted by R_J
      I would install something like a 3~5 amp pigtail fuse in that position and see what happens. The short may not be on the fuse but the circuit that runs off that supply may be loading it down.
      Like I said, based on the power supply rating I can't see it being a 15 amp fuse.
      So after returning from physical therapy this evening I cracked open the TV, piggyback soldered a low current automotive AGC type fuse holder to each end of the fuse and installed a 3A AGC type fuse, all from my auto parts collection. I have plenty of car stuff since before repairing TVs I was a Master Auto Technician and an I-Car certified collision repair/body and paint technician. Currently the TV now has backlights and is in operation in my kitchen. It's been on for 20 minutes.
      There's just one question before I temporarily put the back on it for testing. Since cars are a 12 volt system and this circuit is 24 volt, should I have installed a different rating fuse? I'm thinking it should be ok but I wanted to ask, just in case.
      They call me......."threadkiller"
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        #43
        8 hours run time and the backlights are still on.
        I'm still looking to find out if the current rating on the automotive fuse is 3A at 24V. Anyone? And I meant ATC type fuse in my previous post, not AGC type.
        • R_J
          • 9588
          The voltage rating is not that important in this case. The voltage rating has more to do with the distance between the contacts. an atc fuse would not be good in a 120v circuit, If the fuse opened it might continue to arc across the open fuse element.
          I would just replace it with a 3~5 amp smd fuse that will mount to the pads.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            #45
            Ok so I found a fuse from a t-con board with the markings "YD". The rating printed on the board was 32V 5A. I removed it from the t-con, installed it on my main board, checked it for continuity after the install and it checked good. I installed the main board, plugged it in, turned the TV on and the fuse blew straightaway. Looks like the Main Board has a problem. Now for where to start?
            • cheeky2
              • Dec 2012
              • 337
              #46
              I bet the fuse should have been a slow blow fuse and your fuse you put in it was a fast blow fuse. Which is why it blew straight away!
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                #47
                You may be right. I need to see if I can find the right fuse for it.
                • R_J
                  • 9588
                  Maybe it is indeed a 15amp just to handle the surge. Does it still work with the atc fuse?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #49
                    Yes it does work with the ATC fuse, it's a 3A rated fuse
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • FrancescoV
                      Onkyo HT-R390 no sound output, video output ok
                      by FrancescoV
                      Good morning everyone,
                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                      The firmware reported is the following:
                      M:1.00/11107BLP
                      D:?.??/????????
                      O:1.00/11107AL
                      The DSP firmware given the question marks seems corrupt.
                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                      05-11-2025, 02:59 AM
                    • прямо
                      Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
                      by прямо
                      Just received it today from a friend.
                      Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
                      The same rail also does this when the PSU is in standby mode.
                      https://ibb.co/5TBkg66
                      The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
                      What could have caused that?
                      First time I have seen such behavior.
                      3.3V and 5V rails don't have the same...
                      02-19-2024, 09:52 PM
                      by momaka
                      03-15-2023, 10:17 PM
                      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                      by momaka
                      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                      http://www.rmac.kingwin.com/products.../abt_650MM.asp
                      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                      What mostly drew me into buying it is its 2x PCI-E power connectors...
                      03-29-2022, 11:34 PM
