Sony NSX-32GT1 need blink codes.
  • noonyf
    • Jan 2014
    • 5
    • usa
    Hello, does anyone have the blink code for this model? I have the schematic but it doesn't list the blink codes. After the set is on for a minute or two, it will shut down and blink 10 times.
    thanks
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Re: Sony NSX-32GT1 need blink codes.
    describe in detail what your tv is or isn't doing... maybe we can figure out what the problem is.
    • noonyf
      • Jan 2014
      • 5
      • usa
      all it does is blink 10 times after plugin. nothing else. sony emblem lights up
      • EazyBone
        Sony 85x90CK 4 red blink
        by EazyBone
        So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
        But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
        Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
        Now what is this going to do to the tv? Is it just going to die shortly down the road?...
        07-18-2025, 12:53 PM
      • cheeky2
        Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
        by cheeky2
        For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
        See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
        01-08-2024, 05:56 AM
      • Famo
        Sony KDL-52Z4500 6 Red LED Blink
        by Famo
        Hello badcaps forum.
        I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
        06-09-2023, 10:21 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • EazyBone
        Sony XR-77A80J OLED 5 Blink
        by EazyBone
        Another eazybone post took on this OLED now.
        Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
        I'm thinking I have a power board issue though, which is one of the options
        Now to check pin voltages from PSU to main and PSU to tcon
        Pic 2
        1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
        2 bl err -- 0.16
        3 evdd on --0
        4. Ac off det 3.187
        5 power on -- 3.362 BUT fluctuating randomly to 3.352
        6 stby...
        10-24-2023, 09:09 PM
