Samsung UE55KU6575U SHOWS ONLY HALF SCREEN
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    Re: Samsung UE55KU6575U SHOWS ONLY HALF SCREEN
    Hi budm BN44-00876A
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4314
      • Italy - Milan
      No way! 21 posts and neither one photo of the screen.. is this a game?
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        i couldn't find the pic where someone said it looks like back lights out one side
        • bohaboha
          • Nov 2012
          • 973
          • sweden
          whenianswered budm i had a blackligt just halv the tv now it is just dark
          • bohaboha
            • Nov 2012
            • 973
            • sweden
            petehall347 here it is inthe first post the first 2 pics
            • bohaboha
              • Nov 2012
              • 973
              • sweden
              #26
              watch what happens now when tv lies on the table but it does not light up continuously, it lights up and goes out as if it were giving a code
              here are some pictures
              • bohaboha
                • Nov 2012
                • 973
                • sweden
                #27
                sorry all my measurements were not right because i forgot to have all the cables in their proper place now they are right
                on number 2 on the contact and top row 260v
                on number 2 bottom row I hart 160v
                on number 1 top row 346v
                on the bottom row 246v
                and now the picture back
                  Originally posted by bohaboha
                  Hi budm BN44-00876A
                  OK, so the LED string #1 and #2 are connected in series to form one large string.
                  If you look at the output Voltage as printed board, you will see that the LED power supply is rated at 200V 520mA, right now you are seeing over 300V because the power supply is not seeing the load, so you have open circuit some where in the LED circuit path.
                  Do you have LED tester for testing the LED strings?
                  BTW:
                  Pin 1 (1+) and 3 (1+) are tied together, they are Anode pins for LED string #1.
                  Pin 7 (1-) and pin 9 (1-) are tied together, they are Cathode pins for LED string #1.
                  Pin 2 (2+) and 4 (2+) are tied together, they are Anode pins for LED string #2.
                  Pin 8 (2-) and pin 10 (2-) are tied together, they are Cathode pins for LED string #2.
                  Your report in your post #27 does not make any sense because the pins assignment are 1+, 1-, 2+, and 2-, you do not indicate what the 1+, 1-, 2+, 2- readings are.
                  Pictures provided by shopjimmy.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4314
                    • Italy - Milan
                    #29
                    Now the things goes better, the main problem is the backlight but have you noticed that also the screen matrix is defective (black vertical bar)? is it worth repairing? You better contact an electrician to install a surge discharger in the electrical circuit breaker panel.... and sell the beast fort parts...
                      Yeah, I just notice that vertical bar to.
                      What is the history of this TV?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4314
                        • Italy - Milan
                        #31
                        One moment, it returns in my mind a very similar case, it was some months ago here, if i remember well the user had found a visibly burnt side screen tab/cof...
                        PS: maybe is this: https://www.badcaps.net/forum/showthread.php?t=78997
                        • bohaboha
                          • Nov 2012
                          • 973
                          • sweden
                          #32
                          Hello and thank you all for helping me.
                          budm:I could not figure out what was on the label above the contact
                          because it's the first time for me with such tv plus I'm not a technician except I try and learn through your wonderful help.
                          Davi.p:that's exactly what I usually do. when I saw that this nice TV almost worked then hoped that maybe it was possible to fix for myself to use because I can not afford such stuff.
                          budm,Davi.p,Davi.p:the conclusion is it possible to repair or wasted time?
                          Davi.p:thanks for the reference i will check it out
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4314
                            • Italy - Milan
                            #33
                            So you have picked it up for repair? Check the link well, it spoke about a broken corner after failed led replacement, not the best start, my advice after many years of this sort of business, two question to always make are if the tv is already been serviced because this reveals often bad surprices if you don't want to go mad, the second if you are not a smoker ask if the previous he was, the smell of them is really disgusting!!!
                            • DXseekerMO
                              • Feb 2018
                              • 1119
                              • US
                              #34
                              There's also a horizontal line on the screen. It doesn't look repairable to me....unless I'm missing something.
                              They call me......."threadkiller"
                              • bohaboha
                                • Nov 2012
                                • 973
                                • sweden
                                #35
                                thanks for the answers but it does not give me the final answer can it be repaired or not? and if it does where should I test? very grateful for all the help
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4314
                                  • Italy - Milan
                                  #36
                                  have you read the link?
                                  • bohaboha
                                    • Nov 2012
                                    • 973
                                    • sweden
                                    #37
                                    sure i did.so you think i have similar error? ok i will try thank you very much
                                    • bohaboha
                                      • Nov 2012
                                      • 973
                                      • sweden
                                      #38
                                      Hi all after long time of illness and surgeries now I am back and would like to finish this object and need your professionals help just one last try. now I have discovered that it is very hot in one of the video cards with so many super small smd capacitors
                                      • bohaboha
                                        • Nov 2012
                                        • 973
                                        • sweden
                                        #39
                                        Hi everyone who helped me but the disease took over for a while now I am back and this TV was on the bench in the living room. I discovered that some capacitors in the scren boards are very hot
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Tom C
                                          Samsung QN55Q70AAFXZA Half Screen Dim
                                          by Tom C
                                          I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                                          Any suggestions would be appreciated.
                                          thanks.
                                          09-19-2024, 07:22 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
