Samsung UE55KU6575U SHOWS ONLY HALF SCREEN
  • bohaboha
    • Nov 2012
    • 984
    • sweden
    hi As the title says this curved tv works but shows only half the screen wondering where the fault lies thanks.Here are some pictures
    Note: First and second pictures show the back of the TV the side that works very dark picsorry
  • bohaboha
    • Nov 2012
    • 984
    • sweden
    Re: Samsung UE55KU6575U SHOWS ONLY HALF SCREEN
    Hi no one can help or some ide about this
    • bohaboha
      • Nov 2012
      • 984
      • sweden
      please some help
      • Kilroy2k1
        • Aug 2009
        • 69
        Looks like the backlights are out on one side. Test the backlight LED's with a tester or if you can read the value off the psu a dc power supply set to about 60% of that voltage can work as well.
        • bohaboha
          • Nov 2012
          • 984
          • sweden
          thank you for the answer.am not home now but i will do the test.one question
          is the leds separated left and right?thank you
          • Kilroy2k1
            • Aug 2009
            • 69
            I dont know that specific model but judging by the failure mode I would assume they are.
            • budwich
              • Jul 2015
              • 3097
              look at / near the cable running from the power board to the panel (leds). There is likely some labeling for the pin outs. You can monitor / measure the voltages there at startup. Go from the results which will likely tell if you have led problems. Post a better picture of the power board area to help the forum and yourself.
              • bohaboha
                • Nov 2012
                • 984
                • sweden
                Hi there is not any label to point to any pin you can se it on the pics i hope they are better this time
                • bohaboha
                  • Nov 2012
                  • 984
                  • sweden
                  Kilroy2k1 are these the leds on the last 2 pics?
                  • Kilroy2k1
                    • Aug 2009
                    • 69
                    No those boards in the last 2 photos are the boards that run the LCD screen. They have nothing to do with the LED's
                    The LED's are on that plug thats on the opposite side of the board from the cable that goes to the main board.
                    You will find the pin numbers and what voltages they should have printed near that connector on the power supply.
                    • bohaboha
                      • Nov 2012
                      • 984
                      • sweden
                      please can you point on my pictures because I do not find or do i have take some more pics thank you
                      • Kilroy2k1
                        • Aug 2009
                        • 69
                        Circled in the connector for the led's and printed above it looks like the pinout.
                        • bohaboha
                          • Nov 2012
                          • 984
                          • sweden
                          thank you how can i test it
                          • bohaboha
                            • Nov 2012
                            • 984
                            • sweden
                            The printed above it is realy difficult to read but here wats on it .
                            • Kilroy2k1
                              • Aug 2009
                              • 69
                              There can be some fairly high voltages there, if you dont know how to test it then perhaps you should enlist the help of someone who does to check it over in person.
                              • bohaboha
                                • Nov 2012
                                • 984
                                • sweden
                                well i know there are such highs i can handle it but what tests do you want me to do?
                                • Kilroy2k1
                                  • Aug 2009
                                  • 69
                                  First unplug the cable to the main board and then plug in the power, the back lights should light up.
                                  If they do measure voltage across 1+ and 1- then 2+ and 2-
                                  My guess is you have some backlights out.
                                  • bohaboha
                                    • Nov 2012
                                    • 984
                                    • sweden
                                    Hi again from the ground to 1 cord I get 309v and the bottom one which is also 1 I get 224 it is the same cord I could not decide which is + or -
                                    and secondly that is marked 2 all the time the black probe to the ground I get on the top 224v and for the lower 131v
                                    • bohaboha
                                      • Nov 2012
                                      • 984
                                      • sweden
                                      here are some close-ups of the contact in question I think the top row is + and the bottom is -
                                        What is the power supply board part number?
                                        BN44-??????
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Tom C
                                          Samsung QN55Q70AAFXZA Half Screen Dim
                                          by Tom C
                                          I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                                          Any suggestions would be appreciated.
                                          thanks.
                                          09-19-2024, 07:22 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
