Vizio P-Series: P65-F1 "Standby Light Flickering 1 Second"
  • ajsterr4
    • Jun 2016
    • 115
    I picked up the TV and here's the symptons:
    user said screen started going purple or green then went out, he hard reset TV and i guess it just stopped working completely.
    When the TV is first plugged in the standby light briefly for a second flickers then stops... The rest of the TV is unresponsive... I havent taken it apart yet
    What are the odds of changing out just the power board and other components are ok?
    btw sorry for dupe posts i deleted the old one.
  • ajsterr4
    • Jun 2016
    • 115
    Re: Vizio P-Series: P65-F1 "Standby Light Flickering 1 Second"
    I should mention the standby light only flickers when i plug the device into the wall and then it goes off completely - other than that the tv is completely unresponsive
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • p-top
      Vizio, E60u-D3, no standby light, no ps_on
      by p-top
      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
      PS voltages
      1 VSNS -2mV
      2-5 LED-OUT -2mV
      6-10 GND -2mV
      11 +16VS 16.29V
      12 AC-DET 3.929V
      13PS-ON -3mV
      14 +16VS 16.29V
      15 +16VS 16.29V...
      11-27-2023, 10:44 AM
    • x_orange90_x
      Vizio E550i-A0 no power, no standby light
      by x_orange90_x
      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
      11-20-2023, 09:49 AM
    • shelby5041
      vizio d40f-j09 no pic no sound standby always clear
      by shelby5041
      hi
      anybody have experience with this model tv
      07-19-2025, 06:58 AM
    • reessi
      ACER BM320 Monitor - Horizonal Flickering Lines After a While
      by reessi
      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
      They are black on the right and gradually fade to nothing on the far left.
      They start either after 5 mins or up to 2 hours after so annoying for testing.
      They flicker continuously very fast! With a slight pause milli-second every second.
      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
      I tested each half by removing the first the left flex from...
      06-03-2025, 09:58 AM
