Re: Philips 42PFL3606H/58 Not powering on, no power indicator - PSU problem?
Thanks for the follow up.
Update: the TV is fixed!
I was able to purchase a known good used power supply for 37 Euros (43 USD) and now the TV works properly.
The faulty components on the original power supply were IC801 (UBA2071AT) and IC901 (NCP1271). I will try to obtain these two ICs and change them using soldering paste and heath gun. I'll report it once the original PSU is also fixed.
Thank you all for your help!Last edited by DrOetker; 11-10-2020, 01:05 PM.Leave a comment:
change that ic801, it's obviously fault, but check q801 much probably is at.fault too.Leave a comment:
The voltage at the emitter should be around 12v to 15V. Trunks81 could give you the correct figure. So maybe something could be loading this supply.
Can you meaure the resistance of IC902 between VCC (pin 8) and ground (pin 6)
With Q907 lifted out of circuit what is the voltage across C946
I also measured voltage across Q915 (part of the brown out circuit, equivalent to Q906 on trunks81's board) anq Q918 while the mainboard was plugged in.
Q915:
B = +6.12V
E = +5.84V
C = 0.00V
Q918:
B = 0.00V
E = 0.00V
C = +314V
That means that on my board the brown out circuit is active, is that correct?
I'm sorry, I don't get it, do I need to fully lift Q907 or just one pin of it? What will be easier, to do it using a heath gun or with soldering iron?
I would replace C946 for a start, it is likely bad even though the capacity is reading closeLeave a comment:
With Q907 lifted out of circuit what is the voltage across C946Leave a comment:
I realised that I did not test switch Q907 while the PSU is connected to the motherboard so I tested that now. I also tested IC901 and IC902 (while doing all the testing I used C907 leg as an negative; motherboard was plugged in and it was in working mode).
Q907
PIN 1 (Base) = +7.52V
PIN 2 (Emmiter) = +8.18V
PIN 3 (Collector) = +4.68V
IC901
PIN 1 +0.18V
PIN 2 +2.69V
PIN 3 0.00V
PIN 4 0.00V
PIN 5 0.00V
PIN 6 +4.22
PIN 7 N/A
PIN 8 fluctuates, most of the time it's slowly climbing from +3.5V to +4.1V, it can raise up to +5.05V (rarely), but also I've seen it drop to 0.5V for a second.
Pin function according to the datasheet: https://www.onsemi.com/pub/Collateral/NCP1271-D.PDF
Pin No. Symbol Function Description
1 Skip/latch Skip Adjust or Latchoff
A resistor to ground provides the adjustable standby skip level. Additionally, if this pin is
pulled higher than 8.0 V (typical), the controller latches off the drive.
2 FB Feedback An optocoupler collector pulls this pin low during regulation. If this voltage is less than
the Skip pin voltage, then the driver is pulled low and Soft−Skip mode is activated. If this
pin is open (>3 V) for more than 130 ms, then the controller is placed in a fault mode.
3 CS Current Sense This pin senses the primary current for PWM regulation. The maximum primary current
is limited to 1.0 V / RCS where RCS is the current sense resistor. Additionally, a ramp
resistor Rramp between the current sense node and this pin sets the compensation ramp
for improved stability.
4 Gnd IC Ground −
5 Drv Driver Output The NCP1271's powerful output is capable of driving the gates of large Qg MOSFETs.
6 VCC Supply Voltage This is the positive supply of the device. The operating range is between 10 V (min) and
20 V (max) with a UVLO start threshold 12.6 V (typ).
8 HV High Voltage This pin provides (1) Lossless startup sequence (2) Double hiccup fault mode (3)
Memory for latch−off shutdown and (4) Device protection if VCC is shorted to GND.
IC902
PIN 1 +0.92V
PIN 2 0.00V
PIN 3 +0.01V
PIN 4 0.00V
PIN 5 0.00V
PIN 6 0.00V
PIN 7 0.00V
PIN 8 +4.23V (stable)Last edited by DrOetker; 09-05-2020, 12:37 PM.Leave a comment:
when measuring between 17 and 22 iam getting high ohmage of ic801Leave a comment:
Having a defective ic801 could kill the vcc coming from Q907's collector but if you want to be sure, isolate the emitter of Q806 which supplies ic801's vcc, Q806 is a 13v regulator for ic801 and is fed from Q907's collectorLast edited by R_J; 09-05-2020, 09:05 AM.Leave a comment:
If you lift Q802 and see if
1) the low resistance is gone between the two pins, 17 & 22
2) check the mosfet while out of circuit.Leave a comment:
If you are getting +7.43v on the E and next to nothing on the collector, you likely have either a shorted vcc on ic902, or ic901. D916/C946 are the vcc supply, Q907 is the vcc switch for the pfc and main ic's
If you were to isolate pin 6 on ic901 and the voltage on Q907-C comes up the ic901 is bad, Or you could isolate pin 8 on ic902 and see if the voltage comes up on Q907-C.
If ic901 is the problem, the pfc circuit should work giving +965 volts across C907
If ic902 is the problem, the main circuit should operate and give some voltage on the +24 & +12 volt lines. (likely +12v & +6v) but could be full 24&12 if not loaded
I was searching for more information on some russian sites (since these Philips TVs were popular in eastern Europe) and found this video:
https://www.youtube.com/watch?v=OR-zpuNYXZ0
It was a 32pfl3606H/60 that won't turn on, with good +5VSB voltage and no current on +12V and +24V, exactly like mine. Turns out that IC801 (control chip for CCFL backlight) was defective, he said there was a short between pin 15 and 22, if I understood correctly (I don't speak Russian). After replacing IC801 the unit worked normally, it seems that functional IC801 is also vital in order to get the current on +12V and +24V rails.
That made me wonder about my CCFL control chip (IC801 - UBA2071AT) and I found out that there was very little resistance between pins 17 and 22 (only 3.6 ohms in both direction). Now I'm thinking that on my board a failed IC801 is the culprit and should be changed. I also desoldered and checked polymer capacitor C802, it's capacitance is 332 nF, this should be okay.
I zoomed in on IC801 part of the circuit and attached a picture below.Last edited by DrOetker; 09-05-2020, 06:52 AM.Leave a comment:
Q907 (BC857C) voltages:
1 pin (base) = +7.43V when MB is disconnected, when I place the jumper it fluctuates from +1.45V to +1.7V.
2 pin (emitter) = +7.43V when MB is disconnected, after placing the jumper it fluctuates from +2.09V to +2.40V.
3 pin (collector) = +0.39V (MB disconnected), after plugging jumper it's +1.56V.
If ic902 is the problem, the main circuit should operate and give some voltage on the +24 & +12 volt lines. (likely +12v & +6v) but could be full 24&12 if not loadedLast edited by R_J; 09-04-2020, 10:56 PM.Leave a comment:
Thank you for your input trunks 81 and dick barton.
I have indeed just read your threads and imho it seems that we have similar problems with our boards, although please do note that our boards are not the same (yours is chassis TPM7.1E for Phillips 37'' and 47'', mine is TPM6.1E for 32'' and 42''). There are components that are not the same, for example IC905 is a totally different chip (TOP264VG vs TNY277PN-TL).
I was reading about IC905 (TNY277PN-TL) and looking at the diagram, I'm very curious about BP/M pin and Zener (ZD907) attached to it. ZD908 should be connected with Q907. I will test these components tomorrow.
In order to work properly, higher voltage on C946 is needed. But there aren’t a lot of components in that part of the diagram, so it’s really not clear to me why the current is so weak, could it really be brown out circuit?
While moving the motherboard, a positive leg of C946 got loose, I was curious what would happen and I've done the measurments. When MB was disconnected (without 1k resistor jump +5VSB to S/B) the +5V current was stable at +4.7V. When I inserted 1k +5VSB to S/B jump, the current was stable at +2.16-.17V with very little fluctuation (+- 0.01V). As soon as I put the leg of C946 back to place (with 1k jump), it starts to constantly fluctuate as described earlier (from +2.1V to +4.7V). When desoldered, capacitance of C946 is 50.8 uF, unfortunately I do not possess an ESR meter to test it further.
More testing will be done tomorrow.Last edited by DrOetker; 09-04-2020, 04:42 PM.Leave a comment:
Hello
You can see these topics
https://www.badcaps.net/forum/showthread.php?t=86564
https://www.badcaps.net/forum/showthread.php?t=85509
https://www.badcaps.net/forum/showthread.php?t=86061
Ive have still the working board for the 47 inch so i can measure allong ?
To disable the brown out you most remove R966 and Q906Last edited by trunks81; 09-04-2020, 11:21 AM.Leave a comment:
Do a search for Trunks81 (using the search box at the top of the page) who was recently working on two power supplies similar if not identical to yours where you may find some useful information. If memories serves me, I think the problem may have been in the brown out circuit but I would have to read through the posts to be certain.Last edited by dick_barton; 09-04-2020, 10:29 AM.Leave a comment:
You are using a 1K resistor (or close to that value) when you jump +5VSB to S/B
So you have the +5VSB so it looks like IC905 is working so it should be providing a decent voltage to the emitter of Q907 whicj currently is not the case
I would initially check R959, D916, C946, C915, C922
Thank you for your suggestion, i tested those components.
R959 resistance is 22 ohms, tested in the circuit.
D916 diode - I tested it in diode mode in the circuit, readings are 0.52V and 2.98V. Then I desoldered it, tested it in diode mode agan, and this time values are 0.52V and OL, which should be fine I guess.
C946 cap - desoldered it and tested it, capacity is 50.8 uF.
C915 - in circuit when measuring resistance the values are 60k ohm on one side and 223k ohm on another. Voltage between pins is +1.53V. When checking continuity it isn't shorted. I haven't tested it outside the circuit, that would require heating gun which I don't have, but I can borrow one if it is required.
C922 - desoldered and tested it, measured capacity is 2.3 uF.
I also desoldered MOSFET Q802 (AOTF10N60) because when in circuit in continuity mode it beeps between drain and source in both directions. But out of the circuit, the readings both in diode and continuity mode were fine.Last edited by DrOetker; 09-04-2020, 08:38 AM.Leave a comment:
I would initially check R959, D916, C946, C915, C922Last edited by dick_barton; 09-03-2020, 03:11 PM.Leave a comment:
You are right, I made a mistake. Voltage on pin 1 is higher, I made a mistake regarding the pin order.Last edited by DrOetker; 09-03-2020, 12:57 PM.Leave a comment:
So is +5VSB fluctuating or holding fast when disconnected from the mainboard and no jumper resistors in place?
What voltage do you have on the 3 legs of Q907
Voltages on IC904 (EL817MA):
pin 1 = 4.07V
pin 2 = 5.20V
pin 4 = 0.08-0.12V.Last edited by dick_barton; 09-03-2020, 12:27 PM.Leave a comment:
by ph445Hello,
I have a Philips 40PFH6510/88 TV which is not switching on. No no standby led, no nothing. There was no bang, no smoke, it was simply switched off and next day it did not switch on.
I got the power PCB out and visually checked it, I did not see anything unusal on it, the fuse is OK and no cracked, burned components on either side, capacitors looks OK to me.
Both big 450V capacitors are charging up to around 330V but on the secondary side I can't get any reasonal voltage on any output pins. Most are around 0.2-0.3 V. (not sure which one is standby,... -
by ProtkerHello!
So i have a Philips 47PFH4109, and when i powering on the tv just blinks once, then after a 2 seconds blinks again, and does not turning on.
I mean i measuring voltages such like 30V on the leds and the 12 volts on the other panels, which seems to be okay.
I checked the backlight no issues with the leds.
I checked every component such as all the mosfets, all the diodes, i dont see any bad capacitors (unfortunatelly i only can measure up to 200uF).
I even took out the LD7591 chip and without it doing the same as before.
Im just seeking for advice,... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... -
by CircuitChaosHi!
I have a problem with a faulty PSU in the TV set (as in title) and honestly I'm stuck on it and could use a bit of advice if you don't mind…
The PSU's schematics is attached (psu1.png, psu2.png):
It produces +5VSB (standby), but doesn't produce any other voltage (12V, 24V, backlight). To test it, I connected +5VSB to S/B input (and to ENA input to disable the backlight).
After a bit of measuring I came to these conclusions:
1. +5VSB is produced and stabilized correctly (4.68V with S/B... - Loading...
