Philips TV 42PFL3606H/58 (Thriller) (TPM6.1E) PSU problem (wrong Vdd-S)
  • CircuitChaos
    • Jun 2021
    • 7
    • Poland
    Hi!
    I have a problem with a faulty PSU in the TV set (as in title) and honestly I'm stuck on it and could use a bit of advice if you don't mind…
    The PSU's schematics is attached (psu1.png, psu2.png):
    It produces +5VSB (standby), but doesn't produce any other voltage (12V, 24V, backlight). To test it, I connected +5VSB to S/B input (and to ENA input to disable the backlight).
    After a bit of measuring I came to these conclusions:
    1. +5VSB is produced and stabilized correctly (4.68V with S/B unconnected, 5.19V with S/B connected to +5VSB, is stable under load)
    2. T904 (flyback transformer which produces +5VSB) has an additional winding to power the PFC, 12+24V converter and CCFL inverter (Vdd-S)
    3. Vdd-S is only 4.78V, which is way too low (should be around 14-15V)
    4. Disconnecting it (at Q907's emitter) and providing 14V externally causes the PSU to start and work properly
    During my testing, I disconnected everything (except from C946) from D916's cathode, leaving only T904, R959, D916 and C946 in this fragment, and caught some oscillograms:
    Cathode of D916 (voltage on C946):
    - the voltage correctly goes up to around 15V
    Anode of D916 (input of D916):
    - we can see 15V pulses (OK)
    Pin 4 of T904 (output of the transformer):
    - we can see 15V pulses and it doesn't differ from the anode of D916 (OK)
    …but it got more interesting when I loaded C946 with a 1kΩ resistor (which should draw around 15mA):
    Cathode of D916:
    - we can see that the voltage goes up (I think it's due to the less cycles being skipped by TNY277 because of empty C950 – if I understand the mechanism of regulation in TNY277 correctly), but quickly falls down to 2.5V
    Anode of D916:
    - positive pulses are strongly clamped
    Pin 4 of T904:
    - we can see proper positive pulses around 15V
    R959 seems to be dropping the voltage because the duty cycle of these positive pulses is too low (too many cycles are skipped by TNY277, so positive pulses occur too rarely), but how can it be too low if +5VSB is regulated properly?
    After loading the +5VSB output to skip less pulses, the voltage on C946 went up – loading +5VSB with 1A makes it go up to around 10V, which is still too low and I doubt this PSU needs over 1A to be drawn from +5VSB to work…
    And now I'm stuck. I checked (and even blindly replaced) D916, R959, C946, but they seem fine. The duty cycle cannot be higher, because then +5VSB wouldn't be regulated.
    What am I missing here? What's the trick?
  • R_J
    • 9588
    Re: Philips TV 42PFL3606H/58 (Thriller) (TPM6.1E) PSU problem (wrong Vdd-S)
    Check that ic907 optocoupler is working and that it enables ic905, It could be that the ic is staying in standby (burst mode)
    • CircuitChaos
      • Jun 2021
      • 7
      • Poland
      But load regulation of +5VSB works (it maintains the voltage when I draw current from it), and +5VSB raises from 4.68V to 5.19V when I set S/B high (as expected from the circuit built around IC908). Could it work this way if IC907 was faulty?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It may be worth also checking the zener diodes in that area have not gone short circuit or low resistance.
        • R_J
          • 9588
          What is the voltage on IC905 pin 1 in standby and when S/B pin is turned on? Post pin2's voltage as well, this should determine the state of the ic.
          Check that ZD907 is not bad
          • CircuitChaos
            • Jun 2021
            • 7
            • Poland
            Hi!
            Sorry for the late reply, but life got in the way and I had to suspend it for a while…
            Voltage on IC905 pin 1 varies:
            1. In standby (and Vdd-S not loaded) it's around 0.6V with ripples around 1.25V (every 5ms or so):
            Pin 2 is 5.80V then.
            2. When running, but with Vdd-S not loaded, it's about the same, buth ripples are more frequent (every 1ms or so):
            Pin 2 is 6.28V then.
            3. When running, but with Vdd-S loaded (with a 1kΩ resistor), the ripples are gone. Pin 1 has a stable voltage of 1.26V and pin 2 is at 4.05V (starts at 4.17V and slowly goes down).
            ZD907 seems fine.
            One interesting thing is that I connected the PSU to the TV with additional supply to give proper Vdd-S (it took me some time as the TV isn't in my home, I only have the PSU unit with me) and it produced 12V and 24V, but the backlight didn't work (I don't know yet if it's due to PSU not generating backlight voltage, or if the backlight itself is faulty). I'll have to investigate it closer (it seems like a separate issue, but maybe it's somehow related?).
            • прямо
              Viper22A 5VSB circuit
              by прямо
              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
              01-13-2024, 07:05 PM
            • kotel studios
              FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
              by kotel studios
              Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
              Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
              I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
              Any ideas where to go next?
              02-23-2025, 11:47 AM
            • mrcliem
              CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
              by mrcliem
              Hello...
              I got my self a dead CM V700 PSU, with nothing on +5vsb
              I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
              As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
              The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
              I have read the datasheet and and still can not...
              06-29-2023, 08:18 AM
            • socketa
              Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
              by socketa
              Rescued this one
              Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
              Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
              The 5VSB drops to 2.5V when it 'shuts down'
              And the voltage across the primary cap falls from 335V to 330V at the same moment
              I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
              12-20-2022, 03:06 AM
            • hobostove
              Corsair RM1000e - Help identify 5VSB Zener diode
              by hobostove
              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
              There's a 22ohm resistor that's melted and open, but it still has the bands.
              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
              It looks like the diode connects the source and drain of a TNY284...
              03-27-2025, 02:25 PM
