I have a Philips 40PFH6510/88 TV which is not switching on. No no standby led, no nothing. There was no bang, no smoke, it was simply switched off and next day it did not switch on.
I got the power PCB out and visually checked it, I did not see anything unusal on it, the fuse is OK and no cracked, burned components on either side, capacitors looks OK to me.
Both big 450V capacitors are charging up to around 330V but on the secondary side I can't get any reasonal voltage on any output pins. Most are around 0.2-0.3 V. (not sure which one is standby, but I think standby should be above this level)
I checked all 3 optocouplers, not shorted. I checked all diodes I thought to be a diode, all good.
I replaced 1 FET (K22A10N1) I thought was not OK, but nothing changed. (probably was a waste of time it was good)
I checked what is happening on the transformers' primary side on oscilloscope: nothing, except every 10-12 seconds there's some AC voltage for a couple milliseconds and it goes back to nothing.
Service manual: here
Thanks for any ideas, hoping to learn from this a lot
