Philips 37PFL4606 No Power
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello
    Iam new to this forum an got an question right away !
    Ive got this powersupply and it is not powering on
    The standby led on the chasis is on and when powering on it goes off and then 5 secs later its back.
    Also the blue led on the back off the power supply goes on and then fades away.
    Iam measuring on the + and - on the rectifier 313V ! on C907 iam getting the same 313V.
    On CN903 iam getting +5V even when connecting S/B to +5V iam only getting +5V so no 12v/24V
    What did i miss ?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 37PFL4606 No Power
    Disconnect the mainboard from the power supply and connect a 1K resistor between 5V and S/B pin then check you have 12V and 24V supply.
      Can we see good clear pictures of what we are dealing with?
      • trunks81
        • May 2020
        • 265
        • Nederland
        Hello, i cant test at the moment because i dont have an 1k resistor.. its on the way
        also i attached the photo's from the power supply i more pictures needed let me know
        • trunks81
          • May 2020
          • 265
          • Nederland
          Oke Finally got the resistor.. And connected S/B To 5V
          And i dont see 12V or 24V iam getting 0V
          Only got the 5V
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            The circuit diagram may be similar but it's not your power supply.
            If you look at the labels alongside the pins on the underneath of the psu board ( CN903 ) then you can see that you have the wrong pins connected.
            It should be Pin 11 or 12 (+5V) connected to pin 10 (S/B) using the 1K resistor
            • trunks81
              • May 2020
              • 265
              • Nederland
              Hello
              This is on the power supply
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                OK it looks like one end of that connector is 14 pin and the other end where you have placed the resistor 13 pins which is what confused me.
                With the mainboard still disconnect and the 1K resistor connected what is the DC voltage between the two legs of C907. The woltage will be around 330 - 385V dc so measure carefully
                • petehall347
                  • Jan 2015
                  • 4450
                  • United Kingdom
                  might be wrong but it looks like to me that its been worked on before
                  • trunks81
                    • May 2020
                    • 265
                    • Nederland
                    Hello
                    Between the legs of C907 iam getting 309VDC,
                    Edit is allready replaced D901,Q902 and R919 because board whas doing notting in the begining
                      715G4546-P02-H20-003 power supply Schematic and PCB.
                      OP post #10 "Between the legs of C907 i am getting 309VDC"
                      1) Is your AC line Voltage 230VAC? If it is when the pull-up resistor is not in place the Voltage on the cap should be around 325VDC, and when PS-ON is present it should jump up to 395VDC.
                      2) You need to check the DCV on S/B pin right at the power supply connector to see what you get.
                      3) If the S/B pin does show more then 2VDC, the unpower the board and check the PFC Diode D901 in diode mode and resistance mode.
                      4) If number 3 checked OK then verify that IC902 VCC pin 8 to see if it has Voltage to run it, you must use the negative leg of the main filter cap C907 as the ground ref for the hot side of the circuit, be real careful you are working in the deadly side of the circuit.
                      5) I do not know why the schematic you post does not show the values or designators of the components.
                      • trunks81
                        • May 2020
                        • 265
                        • Nederland
                        Measured S/B pin to ground and iam getting 0V
                        On IC902 pin 8 to ground of Filter cap C907 iam getting only 9.8V, when S/B is connected to 5V when not its 0.34V
                        D901 its 2.5kohm and reverse OL
                          You need to recheck how you have that /SB connected to 5V, it should not be 0V if it is connected correctly.
                          • trunks81
                            • May 2020
                            • 265
                            • Nederland
                            Hello
                            Sorry did not connect S/B to 5V when measuring,
                            But when measuring S/B to GND now iam getting 4.98V
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              You say you are getting 9.8V on IC902 Pin 8 (VCC). This is too low to operate the IC which needs a minimum of 11.5V. Check the voltages on the three legs of Q907
                              • trunks81
                                • May 2020
                                • 265
                                • Nederland
                                Iam getting on all three legs 9.8V
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  This is with the mainboard disconnected from the power supply and the 1K resistor still in place?
                                  • trunks81
                                    • May 2020
                                    • 265
                                    • Nederland
                                    Hello
                                    Mainboard is disconnected from power supply and 1k is stil in place
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      9.8V is too low to run IC902 which requires a minimum of 11.5V to operate according to its datasheet.
                                      Can you receck the voltage at the junction of D915/C946 junction. Use the negative leg of C907 as ground.
                                      • trunks81
                                        • May 2020
                                        • 265
                                        • Nederland
                                        Hi am getting the next values..
                                        On the + of D915 to ground of C907 = 322,4V
                                        On the + of C946 to ground of C907 = 9.85V
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
