Useful meter probe attachments ?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Just ordered some of these of Ebay which look as though they could be quite useful.
    Rated at 30V.
    Re: Useful meter probe attachments ?
    So do you put the existing probe tip into the new stubby probe tip assembly?
    Link to the Ebay for details?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      According to a search on Ebay they attach to your meter leads that have the 4mm plug on the end of the leads. They do appear to have different connection types like some that fit over the existing probes.
      I have a good collection of meter leads so I'm sure I'll have a set that will fit them.
      A search on Ebay for "needle tip probes" brings up many of them for sale.
        12-31-2023, 06:04 AM
      • DXseekerMO
        Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
        by DXseekerMO
        Hello everyone!
        Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
        I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
        Yes
        0%
        1
        All backlight strips are the same quality
        0%
        1
        No
        0%
        0
        12-16-2021, 03:58 PM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
