Sony BRAVIA KDL-40S2010 40 in. LCD Television
  • vinceroger69
    • Mar 2012
    • 6714
    Hi guys i have just been given a Sony BRAVIA KDL-40S2010 to repair the main issue is when changing freeview channels the tv turns off and then back on its identical issue in this thread
    so far i have tested all power supply voltages etc and they are all fine
    https://community.sony.co.uk/t5/othe...ff/td-p/259942
    Im guessing its a firmware issue as only happens when using digital freeview and the person i got it from said it was fine on analogue tv but after the digital switch over the problem started so i have been looking for the firmware for this set as sony may of issued a fix but cant find any can anyone help
    EDIT!! i have just seen this thread does this sound like the correct firmware? if so anyone have a idea on how too install it
    https://quuq.org/forum/index.php?top...28877#msg28877
  • Diah
    • Feb 2013
    • 6424
    Re: Sony BRAVIA KDL-40S2010 40 in. LCD Television
    ist the Digital signal T or C ? i wounder this old set tuner will support the new Digital Mpeg rate !!
    • vinceroger69
      • Mar 2012
      • 6714
      when the set works the digital channels work fine i will upload a picture of the tuner and printing on it
      • Diah
        • Feb 2013
        • 6424
        Digital now some kind of Mpeg4.. the old one was MPEG2.
        i saw with hisense TV when the format the tv cant handle it will turn the set in boot loop.
        • vinceroger69
          • Mar 2012
          • 6714
          did you have a chance too read this link whats your thoughts?
          • Diah
            • Feb 2013
            • 6424
            you didn't answer the question.. your digital signal from air or cable ?
            • vinceroger69
              • Mar 2012
              • 6714
              sorry over the air MPEG-4 AVC i think from a quick google its odd as freeview does work but some times you say go up the channels using the remote the screen will go black the relay will click the tv will come back on the channel you was previously watching i have read a few threads it seems a common issue on sony tvs
              • Diah
                • Feb 2013
                • 6424
                i think as i said before.. the tuner cant handle the signal.. and it looks this set came with several chassis and tuner which people like to switch another MB to receive some channel.
                you check the firmware you have with the one posted at the link you provided... but be sure firmware not enough if the tuner cant handle the signal.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  Thanks i may just advise the person too get a separate freeview box as maybe best cheapest option, like you say this is a older tv set now
                    • 12229
                    • U.S.
                    Could be a voltage problem somewhere on the mainboard.
                    • cheeky2
                      • Dec 2012
                      • 337
                      The issue you will find will be with the FEE board. I found that using the epg would trigger the issue very quickly with these range of Sony TV's. The firmware that this software is for the FEE board, not the main board.
                      It can also cause the TV not to power up at all and give you a flash code error (I think 9 standby flash code).
                      The firmware doesn't always upgrade as I have had a few issues with these in the past.
                      All the information you will find here including the files to resolve:
                      https://quuq.org/forum/index.php?topic=8523.0
                      Good luck
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Out of interest what is an FEE board ?
                        • cheeky2
                          • Dec 2012
                          • 337
                          The FEE board is the board that is physically above the analogue aerial board which contains the memory card reader access port which is behind the CAM slot on these Sony TV's. The access of the sony memory stick (very old memory sticks (don't use a duo one as it will not work!)) is behind a plastic cover on the outside of the TV, adjacent to the CAM slot entrance.
                          See picture of the pcb board.
                          These boards I have used from different size models of TV's from this range and have so far worked correctly when replacing them if the software didn't resolve the issue.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Thanks for the information.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Hi thank you for the information and the link i actually did order these boards from ebay
                              https://www.ebay.co.uk/itm/MAIN-BOAR...72.m2749.l2649
                              the the set now works fine the ebay advert said mainboard but i was not it was the board i needed so i just swapped them both out and the set now works fine and has already been returned to the customer but if i ever have another set with the same fault i may try the firmware so thanks again.
                              The only other issue i noticed on the set myself was hdmi picture size overscan issue (too large) but no option to alter this in any menu settings the customer said it did not bother them so i left it alone.
                                • 12229
                                • U.S.
                                So it was the FEE board that was the issue?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  yes the board with the card slot on.
                                    • 12229
                                    • U.S.
                                    Thanks.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Thanks.
                                      I actually used this tv as my main tv for two days (soak test) the picture quality is not too great as its only 720p and the overscan issue when using hdmi like my firestick was not to good either as i just could not get the hdmi input size to fit the screen correctly (this is another known issue with this set according too various google posts)
                                      https://community.sony.co.uk/t5/othe...i/td-p/2422181
                                        • 12229
                                        • U.S.
                                        Not sure if they are similar but I was having picture size problems with firetv on my kdl 46S4100, seems to be ok after going into display and sound on firetv -display-I set video resolution on 720 and calibrate display is set at 3% scale.
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                          10-16-2024, 05:15 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • Spc.
                                          Sony Bravia KD43XF7596BAEP - Android no picture
                                          by Spc.
                                          Greetings everyone.
                                          I also have Sony Bravia, model:
                                          Sony Bravia KD43XF7596BAEP - Android.
                                          What happend is that image dissapeared while we were watching tv.
                                          Diagnostics:
                                          1. TV turns on, no errors
                                          2. Backlight turs on, no errors
                                          3. Power indicator turns on, white color, no errors
                                          4. Menu works on android, you can hear sound while switching channels
                                          5. Volume up and down works via TV remote and via buttons
                                          6. Tunner works, HEVC / MPEG-4 decoder works
                                          7. I get audio from channels
                                          8. No picture is present,...
                                          05-19-2022, 04:28 AM
