Insignia NSL-42Q-10A no power!
  • kgavionics
    • Apr 2017
    • 152
    Hello
    I have an Insignia NSL-42Q-10A LCD TV which doesn't turn on.It has the only the standby light on!
    Out of all the output voltages, i only get the 5v standby which is normal i think,but when i press on the power button, nothing changes.i have the following output voltages
    On/off --remains low.( by the way what's the purpose of this signal?)
    24V remains low.
    12V remains low.
    5V always high.
    PS_ON always low.
    So clearly, the main board is not sending the Ps-On signal to turn all the voltages ON.I confirmed this by jumping the PS-on signal to the stand by pin, and all the output voltages went high expect the ON/Off signal.
    I think that the mainboard is faulty, but just wanted to confirm that i'm on the right track and i'm open to your suggestions guys.
    I have attached the service manual of the tv( the manual shows Haier brand, but it compatible 100% with my Tv.
    thank you guys
    Re: Insignia NSL-42Q-10A no power!
    You are on the right track.
    Please attach good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with?
    • kgavionics
      • Apr 2017
      • 152
      After visual inspection of the main board, i found some burnt out components, it was on the output side, but i don't know if its gonna be worth the time to fix it.
      One thing, i want to do though, it track where the PS_ON signal is coming from!
        • 12331
        • U.S.
        One there: https://www.ebay.com/itm/INSIGNIA-42...kAAOSwGOVd884o
        • kgavionics
          • Apr 2017
          • 152
          just Ordered one off of ebay for 50 CAD.
          Thank you guys for your inputs!
          • yokoono
            • Apr 2010
            • 515
            You should also find out the reason why those components burned out. Until you replace the motherboard, turn on the power supply and see if the voltages are correct. Also check if you do not have a short supply of t-con.
            P.S The power on voltage is given by the processor and which controls 1-2 transistors.
              • 12331
              • U.S.
              The ebay link I posted was 20 bux U.S.
              • kgavionics
                • Apr 2017
                • 152
                20$+12$ shipping+5$import charges--37USD (50 CAD).
                • kgavionics
                  • Apr 2017
                  • 152
                  When force the Power supply to power on, by jumping the standby 5V pin to PS_ON pin.I get all the voltages (24V, 12V and 5V are all present).Furthermore, i tested almost all the diodes, Mosfets, transformers...on the PSU and they were all ok. At this point, i can confirm that the PSU is alright!
                  Clearly, The mainboard is the culprit.
                  like i said above, i ordered a replacement mainboard. Hopefully, this gonna fix the problem!
                    • 12331
                    • U.S.
                    Ok, damn that sucks when 20 turns into 50.
                    • kgavionics
                      • Apr 2017
                      • 152
                      That's one of the few drawbacks for being Canadian lol
                        What is the history of the TV? I looks like it was hit by power surge due to lighting came through the inputs.
                        https://www.badcaps.net/forum/attach...6&d=1593183670.
                        • kgavionics
                          • Apr 2017
                          • 152
                          I bought this tv for 10$ from a guy on the internet, so i don't have any information about it!
                          As far as i can tell, the power supply did survive the surge!
                          Regarding the T-con board, i'm not sure yet, because it's hidden under a metallic cover, which i'm not willing to take apart for now.I'm gonna wait till i receive the mainboard. From my experience, most of the T-con boards are protected with an input fuse which can be replaced in case it goes bad.
                            • 12331
                            • U.S.
                            Vancouver is cool and they have better average weather than where I live AND less pollution.
                            • kgavionics
                              • Apr 2017
                              • 152
                              Indeed, Vancouver is one of the best ciities not only in North America, but in the whole world.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4541
                                • Italy - Milan
                                It is not.clear by the photos which are the connectors near the burnt things, have you tried to remove U212 after trying to read its marking and.see if it frees from shorts the board and start to work?
                                • kgavionics
                                  • Apr 2017
                                  • 152
                                  Received the main board yesterday, TV working fine! Thank you guys for all your inputs!!!
                                    Thanks for the follow-up on the repair.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4541
                                      • Italy - Milan
                                      What does it take to do what i've said? In a nanosecond you can have two workig boards maybe..
                                      • kgavionics
                                        • Apr 2017
                                        • 152
                                        Originally posted by Davi.p
                                        What does it take to do what i've said? In a nanosecond you can have two working boards maybe..
                                        I really appreciate your suggestion, but the board is heavily damaged, I have found a lot of burnt small IC's! I have some other TV's to work on. This card is beyond economical repair!
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • RossMoodley1967
                                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                          by RossMoodley1967
                                          Hello
                                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                          03-01-2024, 06:07 AM
                                        • MikeRWK
                                          Insignia ns-50dr620ca18 (NS-50DR620NA18) tcon voltages
                                          by MikeRWK
                                          Does anyone know what the voltages should be at the test points on this tcon? I'm mostly concerned with TCON VID1 which is reading 1.1v which seems strange to me....
                                          01-09-2021, 08:01 PM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
