Sony KDL-70R550A has yellow vertical line in it
  • blake.s
    • 123
    I have a sony kdl-70r550a that has a yellow vertical line in it on the right side of the screen. I am trying to determine if this is the panel tabs or if the t-con. T-con usual is not the issue if there are vertical or horizontal lines correct?
    Attached are some pictures. You can see the right side has a discolored vertical line.
    • 12330
    • U.S.
    Re: Sony KDL-70R550A has yellow vertical line in it
    Usually holds true for horizontal lines but I've seen times when even horizontal lines were fixed with a new tcon, did you try cleaning and reseating the ribbon cables from tcon to panel? and make sure the lvds cable from mainboard to tcon is clean and secure in place, never force a connection off, if it don't come off easy something is wrong with procedure.
    • otaku_nut
      Vizio E701i-A3 fixed but now has red vertical line
      by otaku_nut
      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
      08-19-2025, 06:11 PM
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
    • almarhum
      To fix laptop screen vertical line by working on its EDP cable
      by almarhum
      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
      05-07-2024, 02:12 PM
    • gpo23
      Sony KDL-40V3000 - Vertical lines
      by gpo23
      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
      With the new t-con the color are good but there are vertical lines on all the screen :
      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
      Is there a way to fix the vertical lines on the new t-con ?
      Thank you for your help
      gpo23...
      10-04-2023, 09:11 AM
    • mrsith
      Samsung UE58TU7100K - no picture, vertical line
      by mrsith
      Hi.
      Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
      This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
      Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
      02-07-2023, 11:18 AM
