Lg led projector burnt led driver
  • Cryogen
    • Jan 2015
    • 91
    • United Kingdom
    #41
    Re: Lg led projector burnt led driver
    [QUOTE=Diah;977455]i never wrote words not repairable.. just we agree that those pins had no soldering trace on boards which can be jumper to the correct points.
    Oh thanks for clarifying that. I have no idea with budm mentioned this "It is going to be real hard to get the IC pins to make good connection with the solder pads."
    As far as I know, jumper means to connect the pin with an electrical wire directly to the right smd component.
    I don't think I will have any problem doing that.
    • Diah
      • Feb 2013
      • 6558
      budm concern are correct and serious issue too not only about the IC Pins.. but the board how it carbonized specially the back side.
      this boards are sandwich and it had many join points between the top and the back side. ( look on the remarked color )
      so need to look and inspect clearly to let your work bring successful result.
      BTW: the area under the IC should be isolated by isolation tape.. and the pins which missing soldering trace ,you can extend them before you start soldering the IC on boards.. also wish you good luck
        That board may be more than 2-layer board (top trace and bottom trace), if it has inner layers, then the carbonized section may damaged the inner layers.
        • Cryogen
          • Jan 2015
          • 91
          • United Kingdom
          #44
          Oh that gooey stuff? That's not burnt pcb, there is a thick thermal pad on the 3 resistors which I removed and some of it peeled off.
          You can see it on the upper part of one of the three resistors as well.
          Nothing it's burnt there.
            https://www.badcaps.net/forum/attach...4&d=1595911387
            That is carbonized around those solder pads.
            • Cryogen
              • Jan 2015
              • 91
              • United Kingdom
              #46
              First of all, are you trolling? That's not what Diah pointed out.
              Second AGAIN are you trolling?
              I ALREADY TOLD YOU THAT WAS THE OLD PICTURE PRIOR CLEANING THE BOARD!
              This is the picture taken after I cleaned up with rubbing alcohol.
              The only burnt part is the one on the texas instrument led drive.
              What did you do? YOu saw me answering the focal fire post after 5 years and then came looking for my other posts in my profile just to troll me?
              • Diah
                • Feb 2013
                • 6558
                hold on.. LOL take it easy.... any one give point here its kind of help.
                carbonized points removed by cleaning not always mean its just dust on such sandwich boards..
                https://www.badcaps.net/forum/attach...5&d=1595975599
                could you please trace the bath of pins 3 &4 ? it show they go under the L carbonized points budm mentioned before.. if its go under the L this L should be removed and inspect the trace under.. any short happened before could cause more again..
                we just want you to be successful with yours work on LG PROJ.
                • Cryogen
                  • Jan 2015
                  • 91
                  • United Kingdom
                  #48
                  There are no "carbonized points" on the board. Just 4 damn ic solder points who disappeared after the short.
                  I have enough. I think I will manage by myself like I did many other times. I am just wasting time with people who see something that it is not there.
                  • Diah
                    • Feb 2013
                    • 6558
                    you have the boards on yours table and you can see & guess better than us..where the pins should be connected... also clear focused photos help who read over here and like to help and we do... so don't worry..
                    • Cryogen
                      • Jan 2015
                      • 91
                      • United Kingdom
                      #50
                      Sorry mate, I got frustrated by the other foul mouthed guy. I have nothing against you, sorry for dragging you in.
                      I have reported him and I will just ignore him from now on.
                      As I specified, I have it in front of my eyes and I can see no other burnt points apart of the usual 4 pins on the led drive.
                      I am gonna take a better picture tomorrow.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Lets all be friends...
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Cryogen
                          • Jan 2015
                          • 91
                          • United Kingdom
                          #52
                          Took better pictures.
                          Please note again. The last picture shows the 2 thermal pads which left those gooey marks who you assessed as "carbonized traks and pads".
                          the thin one goes beneath the led drive chip and the thick one above the 3 white resistors (where the residues are). They are parallel mounted as I think the 3 resistors heat up quite a lot.
                          If they are still not clear I will try to find the generic macro phone lens I have somewhere in my house.
                          • Cryogen
                            • Jan 2015
                            • 91
                            • United Kingdom
                            #53
                            By all means.
                            Sometimes I get a bit frustrated. The last 4 months has been really stressful at my workplace.
                            I apologise.
                            • Cryogen
                              • Jan 2015
                              • 91
                              • United Kingdom
                              #54
                              So it looks like 5 can be bridged. 8 and 10 go to respectively c506 and c505 and probably pin 9 to c504 on the back.
                              What do you think?
                              • Diah
                                • Feb 2013
                                • 6558
                                from last photo i guess the following
                                10 share pad of 12 &14 ( need to scratch the end little more to see if its go to the right where 12 14 conected
                                9 - c505
                                5 / 8 - they look connected to downside via the place which under the ic ( need to scratch the area of 5 & 8 at the while line of the IC remark to see if this correct guess )
                                • Cryogen
                                  • Jan 2015
                                  • 91
                                  • United Kingdom
                                  #56
                                  9 - c505
                                  Ahhhh I see!
                                  I have never done traces in my life this way, which tool do you think should I use to scratch the traces open? Fine sand paper?
                                  • Diah
                                    • Feb 2013
                                    • 6558
                                    Ahhhh I see!
                                    shave plate enough too.. just remove the green painting color.. here are the area need to scratch
                                    • Cryogen
                                      • Jan 2015
                                      • 91
                                      • United Kingdom
                                      #58
                                      I got that but how, which tool should I use?
                                      • Diah
                                        • Feb 2013
                                        • 6558
                                        LOL ..there is no specific tool , you can use any sharp surface to scratch the top of the area such for example shaving blade
                                        • electomech-fixer
                                          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                          by electomech-fixer
                                          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                          09-15-2025, 01:42 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • osrex
                                          LED DRIVER KEEPS DYING
                                          by osrex
                                          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                          i have no datasheet at all for the LED lights, all i have is its length.
                                          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                          05-05-2025, 03:36 PM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • r38_
                                          Viewsonic VA1616W driver board burned
                                          by r38_
                                          Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
                                          I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
                                          08-20-2022, 10:51 AM
