Viewsonic VA1616W driver board burned
  • r38_
    • Aug 2022
    • 5
    • Argentina
    Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
    I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
  • petehall347
    • Jan 2015
    • 4440
    Re: Viewsonic VA1616W driver board burned
    give it a good cleaning
    • r38_
      • Aug 2022
      • 5
      • Argentina
      I found board schematic, what value would be r12 and r9?
      • R_J
        • Jun 2012
        • 9590
        The resistors are likely 75Ω, but they won't be the problem, I suspect the ic RTL2525LH that is connected to these lines has been destroyed. Buy a new replacement board from aliExp.
        • r38_
          • Aug 2022
          • 5
          • Argentina
          Originally posted by R_J
          The resistors are likely 75Ω, but they won't be the problem, I suspect the ic that is connected to these lines has been destroyed. Buy a new replacement board from aliExp.
          I thought about it, but i didn't found any replacement board in aliexpress or other sites
          • R_J
            • Jun 2012
            • 9590
            Is this not the same board? https://www.aliexpress.com/i/4001097110422.html, You may need to swap the spi ic U6
            • r38_
              • Aug 2022
              • 5
              • Argentina
              Yes, that's the same board. Unfortunately, the board + shipment + import costs, the final price is $60~, which i think is not worth it for a 15' lcd monitor.
              Anyway, thanks for the help!
              • R_J
                • Jun 2012
                • 9590
                It seems odd to me that connecting the vga cable did this, there should only be video signals of around 1v p/p on these lines.
                • lotas
                  • Jan 2016
                  • 4759
                  • Russia
                  Most likely I connected the VGA cable to a hot one (the laptop was connected to the network via an adapter and the monitor was connected to the network).
                  • R_J
                    • Jun 2012
                    • 9590
                    Have you checked the values of R9, R12 and R15? that may not be your problem. Check the voltage on (1_8AVCC1)1.8v and (3_3VCC1) 3.3v
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Hink85
                      Samsung UN65RU8000FXZA Led Driver Board
                      by Hink85
                      Hi All,
                      I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
                      I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
                      08-12-2020, 07:03 AM
