Lg led projector burnt led driver
  • Diah
    • Feb 2013
    • 6449
    Re: Lg led projector burnt led driver
    Originally posted by Cryogen
    I was going to apply 5v on the led drive board and see if something overheats.
    I need to know if pin 9 is the c504 thought.
    I don't wanna jumper and then short the chip again.
    I only have a 12v 3A power supply, that doesn't look like low currents.
    never apply external voltage to the boards..
    i suggest LEDs test... you have now 3 plugs going out from LED box each with many pins,, but they are only one - & + this apply external voltage just be sure of - &+
    3A are safe to test them.
    • Cryogen
      • Jan 2015
      • 91
      • United Kingdom
      Pin 1 is positive on the led drive, pin 10 is negative.
      I would have applied power through power connector board so there is no way I would get it wrong.
      I fixed other stuff this way and never had a problem.
      • Cryogen
        • Jan 2015
        • 91
        • United Kingdom
        here LEDs function on currents level... you are going to use 12 V with low currents.
        So if one of the leds is open, probably it's the led's fault for burning the led driver chip?
        What do you suggest?
        • Diah
          • Feb 2013
          • 6449
          we cant call the defect LEDs as OPEN. because they are RGB type, the defect one mean it explosion after it shorted and effected on LED driver boards as you have in hand.
          the LEDs metal assembly box need to take it in parts & all 3 RGB LED to replace before your working on driver boards take in place.
          • Cryogen
            • Jan 2015
            • 91
            • United Kingdom
            I tested the leds with the 12v 3amp power supply and they all work as they should.
            • Diah
              • Feb 2013
              • 6449
              good sign
              • Cryogen
                • Jan 2015
                • 91
                • United Kingdom
                #27
                good sign
                Yes tell that to my eyes, I am still seeing butterflies as I forgot to turn the last led (the green one) on the other side and it almost blinded me.
                That was a good suggestion though as I found out that the dlp chip had old thermal paste on its side and none directly on the chip. Same thing for the r/g/b leds, dried up paste on the heatsink.
                LG and other manufacturers are cheeky and want to screw up people by the old overheating trick.
                What do you suggest now? Should I go on with the bridging?
                • Diah
                  • Feb 2013
                  • 6449
                  why not... only the driver boards bring it to normal
                  • Cryogen
                    • Jan 2015
                    • 91
                    • United Kingdom
                    #29
                    You think that there is no short on the board and bridging will fix every-thing? I think one or more caps are shorted.
                    • Diah
                      • Feb 2013
                      • 6449
                      LOL.. how could i know.. check SMT component specially ZD / D parts and Q regulators.
                      before 4 years or more i got Benq GP10 LED projector, and the issue was the drivers, the projectors work but no led on.. over one year i used it with external 12v 5A power supply to feeds the RGB LEDs. until i found new LEDs replacement then i fixed the driver.
                      • Cryogen
                        • Jan 2015
                        • 91
                        • United Kingdom
                        #31
                        The diodes and transistors?
                        Yes pin 5 is mosfet related.
                        So I am going to bridge pin 5 with c503 pin 8 with c506 pin 9 with c504 and pin 9 with c505?
                        • Diah
                          • Feb 2013
                          • 6449
                          my looking on the photo pin 5 going inside under the ic not c503
                          • Diah
                            • Feb 2013
                            • 6449
                            if you aligned the new ic at it place you will find pin 5 & 8 the soldering bed flying out? so it look at the photo no more pins on the surface
                            • Cryogen
                              • Jan 2015
                              • 91
                              • United Kingdom
                              #34
                              Sorry can you kindly rephrase that? I didn't get what you mean. So sorry.
                                Diah is trying say that the traces are blown away.
                                This looks really bad to me, so many burnt and damaged trace, board is carbonized from the burnt.
                                That inductor L500 looks burnt to.
                                It is going to be real hard to get the IC pins to make good connection with the solder pads.
                                • Cryogen
                                  • Jan 2015
                                  • 91
                                  • United Kingdom
                                  #36
                                  That's the old picture, did you check the other one after the clean up?
                                  • Cryogen
                                    • Jan 2015
                                    • 91
                                    • United Kingdom
                                    #37
                                    So can we agree on where each pin goes?
                                    Pin 5 = ....?
                                    Pin 8 = ....?
                                    Pin 9 = ....?
                                    Pin10= ....?
                                    I have nothing to lose, I will give it a try.
                                    • Diah
                                      • Feb 2013
                                      • 6449
                                      Diah is trying say that the traces are blown away..
                                      Thanks budm
                                      Pin 5 = ....?
                                      Pin 8 = ....?
                                      Pin 9 = ....?
                                      Pin10= ....?
                                      could you show us clear focused photo only for pins 5 to 14. as i think 10 maybe sharing with 12 &14 same point.
                                      • Cryogen
                                        • Jan 2015
                                        • 91
                                        • United Kingdom
                                        #39
                                        Thanks budm
                                        I don't understand. Earlier you stated that "pin 5,8,10 easy to jumper", now you are telling me that the traces are not repairable.
                                        Don't get me wrong, I thank you very much for the great help but it is just that I am getting a bit confused.
                                        I am gonna take a picture asap from pin 5 to 14 with my new phone arriving tomorrow.
                                        • Diah
                                          • Feb 2013
                                          • 6449
                                          i never wrote words not repairable.. just we agree that those pins had no soldering trace on boards which can be jumper to the correct points.
                                          Pin 5 = ....?
                                          Pin 8 = ....?
                                          Pin 9 = ....?
                                          Pin10= ....?
                                          you have the boards on yours table and you can see & guess better than us..where the pins should be connected... also clear focused photos help who read over here and like to help and we do... so don't worry..
                                          • electomech-fixer
                                            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                            by electomech-fixer
                                            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                            09-15-2025, 01:42 AM
                                          • DynaxSC
                                            Extreme High Current & Low Voltage Short Killer ??
                                            by DynaxSC
                                            Hi Folks
                                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                            After taking off the socket, the shorts dissappear again.
                                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                            10-15-2024, 10:13 AM
                                          • osrex
                                            LED DRIVER KEEPS DYING
                                            by osrex
                                            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                            i have no datasheet at all for the LED lights, all i have is its length.
                                            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                            05-05-2025, 03:36 PM
                                          • r38_
                                            Viewsonic VA1616W driver board burned
                                            by r38_
                                            Hi everyone, i connected my va1616w monitor to netbook and it burned components of the driver board in the vga port area, i think i bad connected the cable by mistake. After this the monitor power on but never receives signal from computer or any connected to vga port.
                                            I didn't find schematics of the driver board. Also i tried a universal lcd controller (mt6820-t) board with the panel but it was not supported. This is repairable or the board is dead? Thanks in advance. Images of the board:
                                            08-20-2022, 10:51 AM
                                          • Stephen
                                            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                            by Stephen
                                            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                            02-06-2025, 12:03 PM
