Samsung LN40B500P3F has Standby light, doesn't turn on.
  • checkport88
    • Mar 2016
    • 22
    I'm trying to fix this Samsung LN40B500P3F LED TV for my grandpa. I suspect that there are problems with the main board based on reading old threads. I'm hoping that somebody still has a service manual for this.
    Backlight comes on when I remove the ribbon cable from the power supply board. I basically want to narrow down the problem so I can decide if I need to replace a board or try to fix it.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LN40B500P3F has Standby light, doesn't turn on.
    Generally if the backlights come on when you disconnect the power supply from the mainboard it tends to be that the required signal from the mainboard is missing.
    Can you post sharp focused pictures of the circuit boards. Add them to the post using the "Go Advanced" button.
    Have you taken any voltage readings at the power supply connector to the mainboard?
    • checkport88
      • Mar 2016
      • 22
      Hopefully those photos come through.
      I haven't measured any voltages yet, I'm not really sure where to start. Thanks.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Does the set react to the remote control. Do you have sound?
        If you can give the pin number, name and voltage read at the connector in the red box to see if there are any voltages missing.
        Pin 1 Name Voltage
        Pin 2 Name Voltage
        Pin 30 Name Voltage
        • checkport88
          • Mar 2016
          • 22
          Here are the voltage readings and a close photo of the pinout. Let me know if you see something that looks wrong.
          Sadly, I don't have the remote control for this TV. I used a Fire stick in the hdmi to check for audio but didn't get anything.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Just out of curiosity what voltage do you have at the fuse (both sides) of the Tcon, if this is your tcon board when you switch on the set.
            When the mainboard is disconnected from the power supply the backlights come on so can you measure the voltage at Pin 23 (Inverter On/Off)
              • 12273
              • U.S.
              Not exactly sure but I'm thinking that this board will work, many of these boards are interchangeable: https://www.ebay.com/itm/Samsung-LN4...sAAOSwZIxe3Wu1
              • checkport88
                • Mar 2016
                • 22
                I wasn't able to access the T Con board because it is behind a rivetted enclusure, see attached. Unless I'm missing something.
                I have attached the voltage readings with all boards plugged in and AC power plugged in, measured from the back of the board. First with power off, then when I pushed the power button. None of the voltages changed when I pushed the power button.
                Let me know if your see anything interesting.
                • MrMagoo
                  • Jun 2015
                  • 6
                  • Oztrailya
                  The Tcon is under that steel cover. You will have to lie the tv screen side down on a large flat surface (kitchen tables are good). Undo the screws that hold the stand and the bracket. with that out of the way you should see four Philips head screws that need to undone. lift the steel cover off the tcon and you should be able to check fuse. If not sure you might want to post picture of the tcon as well.
                  Cheers
                  • neilc6
                    • Nov 2015
                    • 1550
                    Yes likely a bad main board. I have used a 40" main board on a 46" B series.
                    • checkport88
                      • Mar 2016
                      • 22
                      I measured across the TCON fuse while pushing power button, but it measured 0V. Photo of the TCON board attached.
                      I measured PIN23 on the power board, with the main board disconnected, AC plugged in, backlight on... It measured 2.13V.
                      I guess I'll start looking for a replacement for the main board? Some good suggestions on this thread earlier.
                      Let me know if there's anything else I should check.
                        "I measured across the TCON fuse while pushing power button, but it measured 0V. Photo of the TCON board attached."
                        That is not how you check to find out if you have Voltage feeding the T-con board or not and if the fuse is good or not, You test the Voltage of each end of fuse with ref. to circuit ground, in this case, the chassis.
                        You use Ohm mode to check and see if it shows as a short if it is good, infinite resistance if it is blown open, and of course no power applied when testing resistance.
                        • checkport88
                          • Mar 2016
                          • 22
                          You're right, oops I should know better than that. Anyway, I measured the voltage on each side of the TCON fuse with respect to the chassis. It was always at about 0.21V or 0.19V each time I tried, and didn't change when I pushed the power button.
                          Resistance across the TCON fuse was 0.3 Ohms.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            This makes me suspicious that you do indeed have a faulty mainboard. When connected with the power supply the backlights fail to come on (knowing that they work) and it looks as though the tcon supply also fails to be switched on. Tcon fuse is OK.
                            • checkport88
                              • Mar 2016
                              • 22
                              Are you guys generally pretty confident in ordering an alternate main board, like some of the ones listed above? Or should I stick to the exact model main board for this TV?
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                Shopjimmy shows 2 mainboards that will work for you.
                                  • 12273
                                  • U.S.
                                  Well 4 highly regarded members and me think it's a mainboard issue...what the hell give it a try.
                                  • checkport88
                                    • Mar 2016
                                    • 22
                                    I agree, just a couple guys suggested maybe getting a main board that was from a different model, but that is likely to be compatible. Is that something that is widely accepted or is that kind of risky?
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      There may be different models that will give a picture, but the back of the tv wont fit. Inputs are in different places and such, you would have to butcher the back of the tv.
                                      Check with shopjimmy and find a cheap one on ebay.
                                        • 12273
                                        • U.S.
                                        I don't deal with lots of samsungs but I think it was bruce or nick that said a lot of the sammy boards interchange.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • marcinq
                                          Samsung UE60KS7000 No Standby Light
                                          by marcinq
                                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                          05-26-2025, 11:36 AM
                                        • SJX1290
                                          No Standby Light on Samsung SAMSUNG UE65NU7022
                                          by SJX1290
                                          I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
                                          My main suspect is bad flash memory, ...
                                          Any suggestions or can someone please​ check dump file, in the attachment
                                          Thank you...
                                          09-07-2024, 01:35 AM
