Samsung LN40B500P3F has Standby light, doesn't turn on.
  • nomoresonys
    • 12332
    • U.S.
    Re: Samsung LN40B500P3F has Standby light, doesn't turn on.
    Yes looking at the one I linked from ebay, it is not right it has too many rca connectors lol. that was easy to notice, maybe if you could find one that matched your board maybe a 40 or 46??
    • nomoresonys
      • 12332
      • U.S.
      From a quick look around the prices they want for an old lcd mainboard that will likely have issues in the near future is just nutz, I would hunt down a newer tv that needs a little fixing before paying an arm and a leg for an old mainboard...which seems to be what they want.
      • checkport88
        • Mar 2016
        • 22
        Yeah that's what I'm seeing too. I did find one for a reasonable price, it would ship from Mexico, but if reliability is going to be an issue I may send my board to PTS Electronics to get refurbished.
        • nomoresonys
          • 12332
          • U.S.
          May be a good idea, hopefully they give you 6 month or 1 year guarantee.
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • Kaar3l
            Samsung QLED QE65Q7FNAT only standby light
            by Kaar3l
            TV: Samsung QLED QE65Q7FNAT
            PSU: BN4400940A
            MB: BN94-12832K
            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
            09-24-2024, 01:35 PM
          • Nicktronic
            Samsung UN70NU6070F Standby Light flashes twice
            by Nicktronic
            Hey Everyone,
            So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
            I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
            03-27-2023, 07:01 PM
          • marcinq
            Samsung UE60KS7000 No Standby Light
            by marcinq
            I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
            I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
            05-26-2025, 11:36 AM
          • SJX1290
            No Standby Light on Samsung SAMSUNG UE65NU7022
            by SJX1290
            I have Samsung UN65MU6300FXZA with Mainboard BN41-02662A, dead , No Standby Light. I suspect result of main power jumping. Checked all voltages on main board ok,..
            My main suspect is bad flash memory, ...
            Any suggestions or can someone please​ check dump file, in the attachment
            Thank you...
            09-07-2024, 01:35 AM
