Repairing Vizio P42ED PSU Board 53a
  • jondilly1974
    • Nov 2009
    • 38
    OK, since my first repair went well, I am moving on to my next project. This is a PSU board (53a) from a Vizio P42ED 42in Plasma EDTV. These boards are well known for early failures. I have counted a total of 37 caps. Out of these 37 caps, I am going to replace 31 of them. I am going to avoid replacing the 6 largest caps at first. I have tested them (sort of) and feel they are still functional. Not to mention that I have received advice that larger caps are less likely to fail than the medium to small sized caps.
    On to some pictures so you all can see what I am working with...
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Repairing Vizio P42ED PSU Board 53a
    As before the first step is to ID and spec the original caps and make a list.
    Step 2 is to make a cap-map [before removing caps] so if your project gets interrupted and you have to come back later you have a record of what was what.
    Step 3 is to compare the list to the map to make sure you didn't miss any.
    - No one around here has ever missed a cap on their map or their BOM and not found out until after the cap order was 'in'. [~~ RIGHT!~~]
    When I know the brands involved I'll point you to the data sheets so you can spec them out yourself.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Don't forget to indicate polarity on your map.
      Just FYI: #34 and #35 have plastic on top that's held on by the sleeve.
      The plastic will bulge even if the caps itself isn't so you have to push on the plastic with your finger to tell if they are bloated underneath the plastic.
      The plastic is just there as insulation because in some applications the top of the cap could cause grounding problems with nearby parts.
      - Dr Seuss
      • jondilly1974
        • Nov 2009
        • 38
        Some of the caps are in hard to see spots, so my plan was to map out the caps (I simply use the full res photos), verify the PCB polarity notations, and then remove the caps I want to replace. Since I have stickers on each cap, I know where they belong.
        After I have all the caps out, then I can identify all of them in a list and post them here. I think they are mostly Samwha caps. Most of them are too close together or too small to read their specs. I will have the list of caps and specs shortly.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          That works.
          Here is Samwha's e-cap product page.
          http://www.samwha.com/electric/templ...product23.html
          If you find one that isn't there check their 'discontinued products' list.
          - Dr Seuss
          • jondilly1974
            • Nov 2009
            • 38
            Here is a list of the caps I removed:
            1) Samwha WL 50v 470uF 105° S1A 13x20x5
            2) Samwha WL 50v 470uF 105° S1A 13x20x5 (Same as #1)
            3) Samwha WL 16v 1000uF 105° S1A 10x21x5
            4) Samwha RD 35v 470uF 105° S5A 10x17x5
            5) Samwha WL 16v 1000uF 105° S1A 10x21x5 (Same as #3)
            6) Samwha RD 25v 1000uF 105° S6A 10x20x5
            7) Samwha RD 10v 2200uF 105° S5A 10x20x5
            8) Samwha RD 10v 2200uF 105° S5A 10x20x5 (Same as #7)
            9) Samwha RD 10v 2200uF 105° S6A 10x20x5
            10) Samwha RD 10v 2200uF 105° S6A 10x20x5 (Same as #9)
            11) Samwha RD 100v 330uF 105° S5A 13x24x5
            12) Samwha RD 100v 330uF 105° S5A 13x24x5 (Same as #11)
            13) Samwha RD 100v 330uF 105° S5A 13x24x5 (Same as #11)
            14) Samwha RD 100v 330uF 105° S5A 13x24x5 (Same as #11)
            15) Samwha RG 25v 100uF 105° S2A 6x11x2
            16) Samwha RG 50v 4.7uF 105° PDA 5x11x2
            17) Samwha RD 100v 330uF 105° S5A 13x24x5 (Same as #11)
            18) Samwha RD 10v 2200uF 105° S6A 10x20x5 (Same as #9)
            19) Samwha RD 35v 470uF 105° S5A 10x17x5 (Same as #4)
            20) Samwha RG 35v 47uF 105° S4C 6x11x2
            21) Samwha RD 35v 220uF 105° S5A 8x12x3
            22) Samwha RG 250v 1uF 105° S3A 7x11x2
            23) Samwha RG 35v 47uF 105° S3C 7x12x2
            24) Samwha RG 50v 1uF 105° S2C 5x10x2
            25) Samwha RG 50v 1uF 105° S5C 5x10x2
            26) Samwha RG 35v 47uF 105° S4C 6x11x2 (Same as #20)
            27) Samwha RG 50v 22uF 105° S5A 5x11x2
            28) Samwha RG 50v 22uF 105° S5A 5x11x2 (Same as #27)
            29) Samwha RG 50v 22uF 105° S5A 5x11x2 (Same as #27)
            30) Samwha RG 50v 10uF 105° RDA 5x11x2
            31) Samwha RG 50v 47uF 105° S2A 7x10x2
            Now, should I simply replace with the exact same caps? I have not heard bad things about the Samwha brand, but this is a well known chronic issue with this particular model of PSU. I am wondering if switching brands would be advisable?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              No, you look in the data tables for Samwha WL, RD, RG for those caps and find the Ripple and ESR.
              If ESR isn't there just use Ripple.
              Then you find caps of a good brand that meet or beat those specs.
              That's what this was:
              Click on the series name and the pdf specs sheet will come up for that series.
              - Dr Seuss
              • jondilly1974
                • Nov 2009
                • 38
                I can't seem to find a datasheet for the discontinued RG series. They only note that the RG series was replaced by the RD series. I have found the ripple for every RD model that would match up with the RG model. However, there is no RD model that would match #22. What should I do now?
                • Toasty
                  • Jul 2007
                  • 4171
                  >>I can't seem to find a datasheet for the discontinued RG series.<<
                  Attached Samwha RG datasheet.
                  veritas odium parit
                  • jondilly1974
                    • Nov 2009
                    • 38
                    I could only find ripple values for most of the caps (RD & RG). So now I am looking for recommendations on replacement caps.
                    • jondilly1974
                      • Nov 2009
                      • 38
                      OK, so it took me a few hours to do this, but I think I have my cart all set with the proper caps. Anyone that has an input, by all means, please give me any advice you think will help.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Looks like you're gettin' this stuff down.
                        Choices look good.
                        - Dr Seuss
                        • jondilly1974
                          • Nov 2009
                          • 38
                          Sweet! Well, I did have some great tutoring!
                          I am placing my order today, hope to see the caps by early next week.
                          • jondilly1974
                            • Nov 2009
                            • 38
                            Small change of plans. They were out of stock on the first line item (#1-2), so I substituted the HE series instead. I hate waiting for backorders.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              That will work too.
                              - Dr Seuss
                              • jondilly1974
                                • Nov 2009
                                • 38
                                I just noticed that the site no longer calls me a "Newbie"!
                                WooHoo!
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                  by momaka
                                  03-15-2023, 10:17 PM
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • black6host
                                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                  by black6host
                                  Good day!
                                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                  I'm going to replace the caps and I'll be the first...
                                  02-06-2024, 08:22 PM
