Sony KDL46W2000 3 flashes, now no remote.
  • Trevtron
    • Apr 2015
    • 124
    • Portugal
    A neighbour and friend asked me to look at this dinosaur. He's had it since new, about 15 years he reckons and it will have had a lot of use in that time. Though it is no longer the 'primary' TV in the house, it is in the bedroom, but his wife is practically bed-bound so it does a long shift every day. Did.
    Apparently it has been taking longer and longer to come out of standby until the other day when it would not start. He remarked the the red standby LED was flashing instead of turning green.
    As occasionally happens, he went to show me the symptoms and it came on - albeit with an uncomfortable delay. But it displayed as good a picture as can be expected of any elderly Sony LCD. But, as he had a spare set in another room it was decided this one should come back to the surgery anyway. It took two of us to lift it down from a very high wall bracket.
    Back at base and the set performed its no-go accompanied by the 3 flashe pattern of the LED a few seconds after power-up. Seeing the amount of dust that had accumulated on the vents I'm thinking this is going to be a nice easy job for a Sunday hunting some retired capacitors.
    However, after getting the back off there were no obvious bulges or leaks to be seen among the 12 or so electrolytics on the PSU. So my trusty 'Atlas' ESR capacitor tester came into play and although 2 or 3 of the cap's were perhaps just the wrong side of acceptable, there weren't any noticably high resistance ones. I changed the iffy ones, popped the board back in and unsurprisingly was rewarded with nothing more than the 3 LED salute once again. I also inspected the solder side of the board for dodgy solder joints.
    By now it was dinner time and while digesting that I had a quick look on here and found a couple of threads listing similar symptoms. One suggested testing by disconnecting the t-con board. Being an easy one I did this and the LED stayed steady. A quick zap from a remote and it came to life without any undue delay. BUT it now wouldn't go back to standby, or respond in any way to the remote, yet the power buttons on the top of the set worked. I pulled the power, plugged the t-con back in and powered up again and rather surprisingly it still worked, coming straight back on - presumably remembering its previous state(?). Still no remote response but the menu & volume button on the top of the set brought up the appropriate graphics.
    So to summarise - set displayed 3-flash error before disconnecting t-con board, started up OK on remote with t-con board disconnected, still starts up with t-con reconnected but no longer responds to remote.
    It's bed time now, I will check some voltages tomorrow but just hoping someone with more experience with these things might be able to give me some pointers
    Thank you in advance.
    Re: Sony KDL46W2000 3 flashes, now no remote.
    Service manual:
    Chassis WAX2F
    • Trevtron
      • Apr 2015
      • 124
      • Portugal
      Thank you @budm, will get to it when I get home from WORK!
      • Trevtron
        • Apr 2015
        • 124
        • Portugal
        Apparently the 3 flash error (which it no longer does) refers to a fault in the unregulated 10.5V line. It sits around 11.6V while the set is starting up then it rises to 12.something. All other voltages on CN02 seem pretty good too.
        But after being left unplugged for a while it is still a bit sluggish starting up. The relay will click 2 or 3 times ( a few seconds apart) and eventually the backlight kicks in and it will run happily thereafter, but still no response from the remote. I cannot even get it into 'red LED' standby, although the power button on the top of the set does shut it down to 'no LED'.
        • Dangerousk
          Sony Android TV KD-49XE9005 4 red flashes
          by Dangerousk
          Hi there
          Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
          Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
          thanks
          D
          10-27-2024, 06:10 AM
        • thstuff
          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
          by thstuff
          A) TV initially dead
          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
          12-26-2024, 09:10 PM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          by sam_sam_sam
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
        • Scoff
          LG55UB850V no picture or audio - flashing LED's help please?
          by Scoff
          Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
          I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
          We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
          01-26-2022, 06:13 AM
        • NolesFan
          sony kd-85x85j Looking for info on how to remove back cover
          by NolesFan
          Like the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
          03-14-2025, 08:23 PM
