Sony Android TV KD-49XE9005 4 red flashes
  • Dangerousk
    • Feb 2023
    • 13
    • England
    Hi there
    Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
    Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
    thanks
    D
  • Diah
    • Feb 2013
    • 6397
    4x blinking related to LED BL & it could be missing low V 1.8 / Tuner share this too... need inspect carfully starting from LED BL
    • lotas
      • Jan 2016
      • 4651
      • Russia
      Service manual Sony KD-49XE9005....
      • Dangerousk
        • Feb 2023
        • 13
        • England
        thanks Diah
        Agreed on the BL check - I don't do TV so wanted to get schematics/info before poking about too much. Chances are a bad cap or joint as the telly works until something overheats or shuts down
        • Diah
          • Feb 2013
          • 6397
          Originally posted by Dangerousk
          thanks Diah
          you need first , see if yours tuner a separated boards connect to MB. if this case just plug it off and keep the tv on to check no error come as now, and turn BL level under 30 and see if the problem remain or not
          • lotas
            • Jan 2016
            • 4651
            • Russia
            Check that all this is in the service manual.
            • Dangerousk
              • Feb 2023
              • 13
              • England
              thanks Diah and Lotas - will go through the steps and report back
              really appreciate the info
              • Dangerousk
                • Feb 2023
                • 13
                • England
                removed the tuner and same issues. Checked the service diag and shows events recorded July 2023, unless the date/time is messed up. Dont think it is.
                Struggling to locate C464 on BKMS board to test 1.8v to the tuner.
                thanks
                • lotas
                  • Jan 2016
                  • 4651
                  • Russia
                  Look for the IC405 dc/dc converter on the board, this will help you find your capacitor faster.
                  • Dangerousk
                    • Feb 2023
                    • 13
                    • England
                    thanks Lotas - yes found it and 1.78v at several caps around that IC405. when the error detected the voltages shutdown and four red flashes.
                    tuner not connected
                    • Dangerousk
                      • Feb 2023
                      • 13
                      • England
                      have checked fuses and volts and appears to all be there. think is protection. for few seconds tv picture is bright and clear -no dim areas or issues where the display is not as expected.
                      can someone share schematics for this model? - thanks
                      • lotas
                        • Jan 2016
                        • 4651
                        • Russia
                        In SONY TV, engineers install a lot of protections, and at any slightest malfunction, the protection is triggered, over time, the LEDs degrade and they begin to consume more current than is included in the backlight driver, and then the protection will trigger and the TV will be blocked, displaying an error code, even if you change to new (not original) from Aliexpress (made in China), then an error may also occur if the backlight driver does not like something.
                        • Dangerousk
                          • Feb 2023
                          • 13
                          • England
                          i understand - seems a waste not to be able to fix older models that still work fine with equivalent parts to avoid going into landfill. is it possible to bypass protection to get some more use?
                          • lotas
                            • Jan 2016
                            • 4651
                            • Russia
                            There were cases, but after the updates... https://community.sony.at/t5/android...5/td-p/2467934
                            • Ihandyrepair
                              4 red flash led 65X950G boot Sony and android logo but then black
                              by Ihandyrepair
                              HI guys
                              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                              here is the issue
                              I have Sony and android logo. but then 4 led red flash lights front of the tv
                              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                              but then I get black screen and 4 red flash light at the front LED
                              but I get 3 led flash on the LED driver board.
                              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                              so I tried...
                              07-11-2024, 01:45 AM
                            • NolesFan
                              Sony XBR-75X800G - Android start up only and dark blue screen
                              by NolesFan
                              Hello all. Sony XBR-75X800G - Android start up only and dark blue screen. Back lighting works. Music just repeats itself. Remote has limited function. Ive search for model # here but I did not find anything. Thinking its T-con but I dont have what type of numbers Im to have when reading on a MM. Any help would be great. TV is 5 years old. Thanks
                              07-07-2024, 10:13 AM
                            • Spc.
                              Sony Bravia KD43XF7596BAEP - Android no picture
                              by Spc.
                              Greetings everyone.
                              I also have Sony Bravia, model:
                              Sony Bravia KD43XF7596BAEP - Android.
                              What happend is that image dissapeared while we were watching tv.
                              Diagnostics:
                              1. TV turns on, no errors
                              2. Backlight turs on, no errors
                              3. Power indicator turns on, white color, no errors
                              4. Menu works on android, you can hear sound while switching channels
                              5. Volume up and down works via TV remote and via buttons
                              6. Tunner works, HEVC / MPEG-4 decoder works
                              7. I get audio from channels
                              8. No picture is present,...
                              05-19-2022, 04:28 AM
                            • Glaval
                              Sony OLED XBR-65A8G 4 flashes
                              by Glaval
                              Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                              01-23-2025, 04:04 PM
