XBR65X810C Blinking 6 Times - Not turning on
+ More Options
Posts
  • ahmarzo
    Hp 15-cs laptop 5 times dc jack blinking white
    by ahmarzo
    I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
    First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
    Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
    But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
    12-28-2024, 04:46 AM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • NolesFan
    Sony kd-85x85j LED blinking red 6 times
    by NolesFan
    I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
    03-16-2025, 11:50 AM
  • 1centchips
    Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
    by 1centchips
    I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
    The laptop is just out of warranty.
    The laptop continues to freeze randomly with the blinking amber charging light.
    What could be possibly wrong with it?
    I have also disable armoury crate in bios.
    12-17-2024, 05:18 PM
  • shakib200
    Hp ZBook Not turning On / charging led blinking
    by shakib200
    HP Zbook 14U G5 not turning on. When dc connector is connected charging light flashes a solid white light blinking with 5-6 amber lights. Then restart again with no white only continuous amber light but no battery connected. Power supply load taking only 20-30 map. all standby voltage present.
    No schematic found.
    11-17-2023, 11:10 AM
