Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
Problem:
I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
Power Board:
I am getting 5v only. I have unplugged all connectors between the power board and main board and hooked up a 1kOhm resistor from 5v to PWR-ON and I get the 18v. I also hooked up 5v to backlight and the backlights came on. Power board is working.
Main Board:
I replaced 2 bulging capacitors on the main board in the DC/DC converter on the main board.
I am getting 5v only at the connector J1 on the main board. The 3 fuses at J1 are good. I have checked the smd transistors and mosfets in the DC/DC converter and they seem ok (did not remove from board).
I did Budm's suggestion to apply heat to DC/DC converter with a hair dryer except I used a heat gun and the blinking power light went out and stayed out. I think I overdid it with the heat and damaged the U50 dual mosfet. I had a close replacement so I swapped it out which caused other problems but in the end I am back to the blinking power light.
I went through the DC/DC converter troublshooting Budm posted and the results are:
J1 Pin 10,11,12,13,14 display 5v
J1 Pin 1,2 display 0v (pin 17 displays 0v)
J6 Pin 1,2 dispaly 0v
U1 pin 5,6,7,8 display 3.3v
U5, U7 display 3.3 v U88, U89 display 0v
U50 Pin 1,2,3,4 display 5v Pin 5,6,7,8 display 0v
U71,U94 display 0v
J6 Pin 1,2 display 0v
Any help or suggestions would be greatly appreciated.
Problem:
Power Board:
Main Board:
U71,U94 display 0v
