TVC digiquest dgq2212v fhdStandby ied flashes 6 times
  • poweron
    • May 2019
    • 371
    • italy
    hello everyone, at power on the red led flashes as normal then very short pause and starts flashing in cycles of 6 flashes, I tried to save the firmware of the two chips U10 and U12 and then to reprogram them without result, at this point I don't know if the firmware is corrupt or the chips are defective, or the problem lies elsewhere? tensions seem right, what do you recommend?
    thank you.
    main :17MB82S 12volt
    panel :T215HVN01
  • notallbad
    • Oct 2012
    • 1190
    Re: TVC digiquest dgq2212v fhdStandby ied flashes 6 times
    People here like to see the boards and board layout before helping!
      thank you.
      panel :T215HVN01
      What are the Voltage readings?
      We also need good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
      • Davy no Caps
        Vestel 17MB82S EEprom dump required
        by Davy no Caps
        First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
        Power Board - 17IPS11
        Mainboard - 17MBS82S
        Panel - VES315WNDB-02
        Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
        Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
        No picture, backlight or sound just blinking...
        06-06-2025, 03:22 PM
      • provider22
        samsung UA32d4OO RED LIGHT FLASHES 3 TIMES
        by provider22
        11-19-2025, 02:45 AM
      • ugamazing
        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
        by ugamazing
        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
        08-31-2022, 07:34 AM
      • Egidio85
        Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
        by Egidio85
        Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
        the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
        the fan does not start.
        I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
        any advice on what to check?
        06-10-2025, 05:00 AM
      • esqmooo
        HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
        by esqmooo
        I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
        03-07-2025, 05:55 AM
