Samsung UN55F8000 BXZA - No HDMI after power surge
  • Chris24
    • Feb 2014
    • 42
    Hey all,
    Got a Samsung UN55F8000 and the HDMI went out after a power outage. EVERYTHING ELSE WORKS fine. Have tested the HDMIs with multiple wires, and other sources VGA, AV etc all still work. TV is a daily living room TV just would be nice to get HDMI back.
    Suspect Mainboard/ Mainboard CPU
    Got a main board off EBay and swapped out mainboard and surprisingly TV would power on, click three times, and power off. I took the eBay board out immediately to not do any additional damage. Upon further inspection the seller (TV parts lots of reviews) has quite a few “board was bad” reviews.
    Did I miss a step in mainboard install (reset firmware) or checking the Tcon or power supply for an HDMI malfunction? Plan on returning the eBay mainboard for a “tested” board and trying again but thought I'd check you guys first.
    Appreciate any feedback!
  • R_J
    • 9551
    Re: Samsung UN55F8000 BXZA - No HDMI after power surge
    You need to match the number on the white sticker not the bare board number.
    • CapLeaker
      Leaking Member
      • 8196
      That silicon image HDMI switch IC on the main board failed.
      • Chris24
        • Feb 2014
        • 42
        Thanks RJ great point - I forgot to add yes the boards are both BN94-06218B on large sticker and BN97-07157A on small sticker. The other random numbers matched (even the date) except for a a few. The eBay board looks like the heat sinks were removed and put back on so I think this board is not from a working tv.
        If the board was wrong match, would the power kick off? What I’m essentially trying to narrow down is if I just have wrong/bad board, or if there is something else wrong on the other boards too (despite all else working but the HDMI.
        CAPleaker- which IC is the silicon image HDMI switch IC? Image below (eBay board- faulty board is back in TV).
        • Chris24
          • Feb 2014
          • 42
          Main board
          • R_J
            • 9551
            The hdmi port processor ic is ic601 (marked Silicon Image)
            • CapLeaker
              Leaking Member
              • 8196
              right there where the hdmi ports are bottom left.
              • Chris24
                • Feb 2014
                • 42
                Cool I see it. Unfortunately don’t have the expertise to replace that IC myself. Based on your responses I think I’ll return this eat board that won’t power TV on and try for a better verified replacement. Will let you know how it works out
                  • 12206
                  • U.S.
                  One there for 94 bucks, there's a make offer option: https://www.ebay.com/itm/Samsung-BN9...kAAOSwD3peVFC5
                    • 12206
                    • U.S.
                    Your model is Samsung UN55F8000BFXZA correct? I'm assuming you missed a letter.
                    • Chris24
                      • Feb 2014
                      • 42
                      Re: Samsung UN55F8000 BFXZA - No HDMI after power surge
                      Awesome thanks. This matches my board number and you are correct it is BFXZA. I updated the thread in case people are searching and I get this fixed.
                      • Nick's Tvs
                        • Jan 2014
                        • 621
                        Just to add a bit further information to this thread, but if you are looking to purchase a replacement board, don't worry about the board numbers, part numbers, or model numbers. Just look at the picture of the board they are selling and make sure it's not a different variant for Europe or Latin america, unless you want that version. The Tuner pieces will be different for certain countries.
                        All the these boards are interchangeable, if you have the 46" 55" 60" or 75" they are all cross compatible with one another. We repair these boards and test them all with the exact same test set without any issues.
                        This is applicable to almost all Samsung LED main boards BTW.
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • mrtek
                          Samsung UN43NU6950FXZA No power
                          by mrtek
                          Hi
                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                          Main fuse = OK
                          Back light LED = OK. Power them with aux power source
                          LED output = OK 156V
                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                          07-20-2025, 08:06 PM
                        • stylishconsultant
                          un60j620dafxza - Samsung No Display Problem
                          by stylishconsultant
                          Hi All,
                          Need help.
                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                          09-04-2024, 03:26 AM
                        • hill01
                          Samsung UE75MU7009TXZG Endless Power Cycle
                          by hill01
                          Hi everyone and thanks in advance for any help I might get here
                          My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                          About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                          Since a few days, the TV won't turn...
                          11-17-2021, 02:52 PM
