Insignia NS-50DR620NA18 has vertical colored lines, no picture. swapped out tcon board but same issue.
Insignia NS-50DR620NA18 vertical colored lines no picture
Re: Insignia NS-50DR620NA18 vertical colored lines no picture
Welcome to Badcaps!
Can you give some history on this TV unit?
- Did this just happen one day?
- Did you get this used?
- What's the ORIGINAL T-CON part number, whats the NEW T-CON part number?Last edited by ngth82; 04-03-2020, 03:56 PM.-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun. -
Purchased used. Trying to fix. New tcon and old tcon are the same as I made shopjimmy check 55t32-c0f. The menu seems to scroll behind the bars/lines. Can not see though. I think the tv is 3 years old.
Attached Filesif you find these attachements useful please consider making a small donation to the site
Any idea if the original owner took this thing apart?
With the back cover removed and the TV on, what happens if you lightly press on the flex cables between the LCD display and the narrow PCBs that connect to the LCD? Does it change the output behavior?
(Example picture attached).Attached Filesif you find these attachements useful please consider making a small donation to the site
-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
with my experience, vertical colored lines are cause by main board failures. tcon board issues are usually either no picture or half of a good picture. from your picture however, they didnt look like colored lines i usually see. being that you replaced the tcon, that leaves the main board and the display panel itself. main board is cheaper, id start there.Comment
What do you get when you do the same to the other side??Comment
Did you remove the metal frame of the LCD panel assembly to get the tab bonding board (as shown on post 5) and inspect them? Right now the problem is the LCD panel not T-CON or main board.
Can we the whole backside of the TV showing all the boards?
Is the tab bonding board located on the top or the bottom edge of the LCD panel?Last edited by budm; 04-07-2020, 04:14 PM.Never stop learning
Check the MLCC caps on the driver board between the tcon and panel for low ohms, ohm mode with tv unplugged from power.Last edited by nomoresonys; 04-07-2020, 04:16 PM.Comment
Big problem when it comes to testing and finding out what's wrong, I'd grab a digital multimeter from one of the big box stores, about 10 bucks or so.Comment
There's a ton of posts here regarding that, basically if you find one reading off, involves removing the small MLCC caps on the board one at a time and checking it and rechecking the rest on the board, til you find the right one, they are in series so one bad one can make others read bad. It could also be a different problem on the panel but many times it was just one of those silly little caps at fault.Last edited by nomoresonys; 04-07-2020, 05:12 PM.Comment
Well, if you do not have meter to check the resistance of the caps on the tab bonding then you will have bigger problem removing the bad caps and install new caps due to lack of tools and experience.Never stop learning
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by srsI'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables... -
by pniHi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... - Loading...
