Insignia NS-50DR620NA18 vertical colored lines no picture
  • daxlw
    daxlw
    • Apr 2020
    • 17
    Insignia NS-50DR620NA18 has vertical colored lines, no picture. swapped out tcon board but same issue.
  • ngth82
    • Jul 2015
    • 541
    Re: Insignia NS-50DR620NA18 vertical colored lines no picture
    Welcome to Badcaps!
    Can you give some history on this TV unit?
    - Did this just happen one day?
    - Did you get this used?
    - What's the ORIGINAL T-CON part number, whats the NEW T-CON part number?
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • daxlw
      daxlw
      • Apr 2020
      • 17
      Purchased used. Trying to fix. New tcon and old tcon are the same as I made shopjimmy check 55t32-c0f. The menu seems to scroll behind the bars/lines. Can not see though. I think the tv is 3 years old.
      • daxlw
        daxlw
        • Apr 2020
        • 17
        Tt
        • ngth82
          • Jul 2015
          • 541
          Any idea if the original owner took this thing apart?
          With the back cover removed and the TV on, what happens if you lightly press on the flex cables between the LCD display and the narrow PCBs that connect to the LCD? Does it change the output behavior?
          (Example picture attached).
          -Thomas
          • jostewcrew
            • Mar 2020
            • 79
            with my experience, vertical colored lines are cause by main board failures. tcon board issues are usually either no picture or half of a good picture. from your picture however, they didnt look like colored lines i usually see. being that you replaced the tcon, that leaves the main board and the display panel itself. main board is cheaper, id start there.
            • daxlw
              daxlw
              • Apr 2020
              • 17
              I applied pressure to the PCBs and there was not a change.
              • daxlw
                daxlw
                • Apr 2020
                • 17
                Replaced main board and tcon. same issue. possible new tcon is bad?
                • neilc6
                  • Nov 2015
                  • 1550
                  Vertical lines are usually signs of a bad panel. You can try powering up one side of the screen at a time by disconnecting the ribbon cable and see if one side shows a good picture.
                  • daxlw
                    daxlw
                    • Apr 2020
                    • 17
                    yes. Half the panel works with one side ribbon off.
                    Is it worth fixing?
                      • 12141
                      • U.S.
                      What do you get when you do the same to the other side??
                      • daxlw
                        daxlw
                        • Apr 2020
                        • 17
                        I get the colored vertical lines on that half
                          Did you remove the metal frame of the LCD panel assembly to get the tab bonding board (as shown on post 5) and inspect them? Right now the problem is the LCD panel not T-CON or main board.
                          Can we the whole backside of the TV showing all the boards?
                          Is the tab bonding board located on the top or the bottom edge of the LCD panel?
                            • 12141
                            • U.S.
                            Check the MLCC caps on the driver board between the tcon and panel for low ohms, ohm mode with tv unplugged from power.
                            • daxlw
                              daxlw
                              • Apr 2020
                              • 17
                              The narrow pcb's are on the bottom. I pressed them and it did not have any change. I will inspect again. I do not have any way to detect ohms.
                                • 12141
                                • U.S.
                                Big problem when it comes to testing and finding out what's wrong, I'd grab a digital multimeter from one of the big box stores, about 10 bucks or so.
                                • daxlw
                                  daxlw
                                  • Apr 2020
                                  • 17
                                  I will see if I can get one but what would be the steps and likely issues from here and fixes?
                                    • 12141
                                    • U.S.
                                    There's a ton of posts here regarding that, basically if you find one reading off, involves removing the small MLCC caps on the board one at a time and checking it and rechecking the rest on the board, til you find the right one, they are in series so one bad one can make others read bad. It could also be a different problem on the panel but many times it was just one of those silly little caps at fault.
                                    • daxlw
                                      daxlw
                                      • Apr 2020
                                      • 17
                                      Can they be replaced or repaired? What search words would you use on the forum? caps? pcbs?
                                        Well, if you do not have meter to check the resistance of the caps on the tab bonding then you will have bigger problem removing the bad caps and install new caps due to lack of tools and experience.
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • srs
                                          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                                          by srs
                                          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                                          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                                          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                                          04-22-2023, 02:40 PM
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          Today, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Superluminal
                                          LG 47LV5500-UA Vertical Colored Lines/Alignment Issue
                                          by Superluminal
                                          Hi all, looking for some input on this one. I've been reading the forums for quite some time but this is my first time posting for help.
                                          LG 47LV5500-UA
                                          10 years old
                                          20,000+ hours on it.
                                          Watching TV on it last week and right while I was watching the image suddenly started experiencing the symptoms in pics. Rainbow chromatic vertical lines and alignment issues. The issue is uniform across the entire panel. It does not come and go, the symptoms are stable.
                                          Here is what I've tried so far:
                                          - Factory reset and cycle of picture options....
                                          11-19-2022, 07:41 PM
