Sony 46HX900 power supply dead
  • renee
    • Jun 2010
    • 21
    please help me to find volts PRI_VCC on C6206 sony G6 power supply
  • renee
    • Jun 2010
    • 21
    Re: Sony 46HX900 power supply dead
    friends i am unable to find IC MIP2H2 so going to change its stanby control.
    i have need output volt from D6204 on C6206
      1) What do you use for GND test point when you are measuring Voltages on the HOT side of the circuit?
      2) Did you check the Fusible resistor (10 Ohms) R6201 to make sure it is showing 10 Ohms.
      3) What Voltage do you have on STB_IN?
      4) What is your country AC Voltage, 120V? 230?
      5) Upload the schematic of the power supply you have.
      • R_J
        • 9625
        Like budm said, check R6201, if it is open, IC6201 is likely bad, you will need to replace both
        • renee
          • Jun 2010
          • 21
          we are using 220 here is attachments with detail
            So what Voltage do you have on the VCC pin of the IC?
            R6204, D6204, D 6205, C6205 are good?
            • renee
              • Jun 2010
              • 21
              R6204, D6204, D 6205, C6205 are ok
              pin1 0
              pin2 0
              pin3 0 0 1 2 then comeback 2 1 0 repeatedly
              pin4 0
              pin5 350
              pin7 0
              pin8 0
              • renee
                • Jun 2010
                • 21
                • R_J
                  • 9625
                  Did you replace the MIP2H2?
                  • renee
                    • Jun 2010
                    • 21
                    Ic is not available in local market so going to modify standby circuit i have just to confirm its PRI_VCC volt.
                    12v, 5v or other
                    • renee
                      • Jun 2010
                      • 21
                      • renee
                        • Jun 2010
                        • 21
                        i have replace the ic
                        volts on ic
                        pin1 5.8v
                        pin2 1.8v
                        pin3 0-2v 2v-0 repeating
                        pin4 4v
                        pin5 350v
                        Pin 7,8 0v
                        voltage on pin3 are varying 0-2 2-0
                        plz help to resolve this issue
                          • 12331
                          • U.S.
                          Is C6210 ok?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Is the STBY_3.3 voltage stable?
                            Have you checked the following components?
                            D6204
                            D6205
                            D6251
                            C6205
                            C6206
                            C6252
                            R6204
                            • renee
                              • Jun 2010
                              • 21
                              i m getting same voltage after changing on all ic's
                              • renee
                                • Jun 2010
                                • 21
                                D6204
                                D6205
                                D6251
                                C6205
                                C6206
                                C6252
                                R6204
                                All components are ok and STBY_0 voltage ,
                                i have replace the ic. new and old both ic's giving same voltage
                                all ic (MIP2H2) giving same volts
                                pin1 5.8v
                                pin2 1.8v
                                pin4 4v
                                pin5 350v
                                Pin 7,8 0v
                                  • 12331
                                  • U.S.
                                  So you are saying that you took those caps off and checked them with an esr meter??
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    You are getting 4V on pin 4 which is the supply input for the IC. That voltage is coming from somewhere.
                                    What point are you using as ground (negative lead of meter) reference to measure the voltages on IC6201
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      What point are you using for the ground reference (negative lead of meter) to measure the voltages on IC6201
                                      • renee
                                        • Jun 2010
                                        • 21
                                        i am using C6510 negative point
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
