PN50C590G4FXZA Horizontal Solid Black line
  • Super360
    • Jul 2016
    • 243
    Hi welcome to the start of the end of the world lol, anyways my tv just recently showed a solid thin black line. Is this easily fixable by replacing the buffer board or is this set screwed? I don't have much experience with plasma tvs. So if yall could tell me how to diagnose a board or maybe what to do next thanks.
    6
    YES
    0%
    3
    NO
    0%
    3
  • Super360
    • Jul 2016
    • 243
    Re: PN50C590G4FXZA Horizontal Solid Black line
    I'm thinking about buying this https://www.tvpartstoday.com/BN96-12...a.htm?CartID=1. Would that work out?
    • diif
      • Feb 2014
      • 6978
      • England
      Here's a good video showing how to test the buffer board for shorts. https://www.youtube.com/watch?v=51SZsfH60EY
      Your board should work but double check the sticker on your buffer to confirm.
      • Super360
        • Jul 2016
        • 243
        I will do that, thanks.
        • Super360
          • Jul 2016
          • 243
          https://www.tvpartstoday.com/LJ92-01...j92-01680a.htm Well i just bought that board. When i receive it i will tell you guys what's going on, Thanks guys.
          • Super360
            • Jul 2016
            • 243
            I also just wanted to say that after i took it apart, I took the chance to blow it out with a air compressor and clean the crap out of this thing. I might as well as i have it apart and i also tightened all the ground screws as they were very loose. I now just am waiting for this board to ship and i hope the plasma screen isn't dead.
            • brucetv
              • May 2015
              • 281
              • united states
              Take a piece of tape and place it on the bezel right where you see that black line and then re-seat that ribbon cable where the tape is on the ribbon cable from the panel into the buffer board. If it's not in position right it will cause a horizontal black line. Sometimes it takes a few tries so be patient and be careful with those ribbon cables. Once you get it positioned right the black line should go away. Since the others are fine don't try to re-seat them.
              • Super360
                • Jul 2016
                • 243
                I will do that once i get my new board and tbh i don't think it's a connection issue i took of every ribbon cable and used a toothbrush and rubbing alcohol on both the connector and the ribbon and then re-seated all of them tight. Just a little update i tried what you said and it had no effect so i guess i'll just wait till the new board get here and pray it's not a plasma failure instead of a bad buffer board, thanks guys.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  bad buffer connection
                  locate the connector that aligns with the line and unclip and reclip a few times (dont take out the strap) shout fix the issue , do it with now power
                  • Super360
                    • Jul 2016
                    • 243
                    I appreciate the help but as i stated i already have taken every connector off and cleaned it with rubbing alcohol. I then re-seated every connection and it had no effect, Thanks for the input though.
                    • budwich
                      • Jul 2015
                      • 3097
                      did you try both side?
                      • Super360
                        • Jul 2016
                        • 243
                        If you are talking about what the y buffer board plugs into then yes. I took out the y buffer board and i cleaned all those connections, put the y buffer board back in and still nothing. I'm not touching the x main yet.
                        • budwich
                          • Jul 2015
                          • 3097
                          do you actually know which cable on the buffer board is responsible for that line?
                          • Super360
                            • Jul 2016
                            • 243
                            My board is coming in tomorrow so i don't really know. I'll update you guys if the new board fixes it.
                            • budwich
                              • Jul 2015
                              • 3097
                              I do believe that you can disconnect one cable at a time which should reveal a "black section" as a result... from there you can determine which cable is associated with the black line. I think that's how it works.
                              • Super360
                                • Jul 2016
                                • 243
                                You know i wanted to do that but the problem is i have heard bad things happening when you unplug stuff with a high voltage plasma.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  that's true but I think it depends. In this case, it would be no difference than an improper plugged cable. Anyway, you are getting / going to try another buffer card which is fine. The test (of unplugged cable) is so that you can understand which cable may be an issue and then focus your attention very close on that area). Based on my limited experience, the black line is the result of no signal making it down that "section". As you have tried (and others suggested, some get lucky) find reseating is necessary. From my limited experience (mostly LCD but does apply), this is a very "delicate" operation in terms of alignment / seating.... misalignment does happen among other things. Hopefully your replacement will solve the problem.
                                  • Super360
                                    • Jul 2016
                                    • 243
                                    Just a little update swapped in the new board to only have it still have the same issue, damn that sucks. I guess i will have to deal with a black horizontal line now. I also reconnected all the x-main connections and nothing. I had a lot of faith in plasmas but now i know why everyone hates these things. I'm just going to sell the boards on ebay and make back some money now.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      I think you should try narrow down which connector the line is associated with. It might help.... maybe as then you may be able focus a bit more on that part of the connector.
                                      Its too bad ... I like my two plasmas (both 50, panasonic and samsung).
                                      • Super360
                                        • Jul 2016
                                        • 243
                                        I have tried reconnecting this damn thing 50 times, putting pressure on it everything. It's obviously in the panel traces or something. It only has 1 small horizontal line so i will use it until more lines show up and then part this beast out. It's a damn shame for a 10 year old tv, the picture quality is amazing in my opinion.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • rstrube
                                          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                                          by rstrube
                                          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                                          Hi Everyone,
                                          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                                          Today, 01:37 PM
                                        • rstrube
                                          by rstrube
                                          Hi Everyone,
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                                          Today, 12:19 PM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • cubytus
                                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                          by cubytus
                                          Hi to all,
                                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                          01-10-2024, 01:26 AM
