Hi welcome to the start of the end of the world lol, anyways my tv just recently showed a solid thin black line. Is this easily fixable by replacing the buffer board or is this set screwed? I don't have much experience with plasma tvs. So if yall could tell me how to diagnose a board or maybe what to do next thanks.
PN50C590G4FXZA Horizontal Solid Black line
Re: PN50C590G4FXZA Horizontal Solid Black line
I'm thinking about buying this https://www.tvpartstoday.com/BN96-12...a.htm?CartID=1. Would that work out? -
Here's a good video showing how to test the buffer board for shorts. https://www.youtube.com/watch?v=51SZsfH60EY
Your board should work but double check the sticker on your buffer to confirm.Comment
https://www.tvpartstoday.com/LJ92-01...j92-01680a.htm Well i just bought that board. When i receive it i will tell you guys what's going on, Thanks guys.Comment
I also just wanted to say that after i took it apart, I took the chance to blow it out with a air compressor and clean the crap out of this thing. I might as well as i have it apart and i also tightened all the ground screws as they were very loose. I now just am waiting for this board to ship and i hope the plasma screen isn't dead.Comment
Take a piece of tape and place it on the bezel right where you see that black line and then re-seat that ribbon cable where the tape is on the ribbon cable from the panel into the buffer board. If it's not in position right it will cause a horizontal black line. Sometimes it takes a few tries so be patient and be careful with those ribbon cables. Once you get it positioned right the black line should go away. Since the others are fine don't try to re-seat them.Comment
I will do that once i get my new board and tbh i don't think it's a connection issue i took of every ribbon cable and used a toothbrush and rubbing alcohol on both the connector and the ribbon and then re-seated all of them tight. Just a little update i tried what you said and it had no effect so i guess i'll just wait till the new board get here and pray it's not a plasma failure instead of a bad buffer board, thanks guys.Last edited by Super360; 03-23-2020, 02:34 PM.Comment
bad buffer connection
locate the connector that aligns with the line and unclip and reclip a few times (dont take out the strap) shout fix the issue , do it with now powerComment
I appreciate the help but as i stated i already have taken every connector off and cleaned it with rubbing alcohol. I then re-seated every connection and it had no effect, Thanks for the input though.Comment
I do believe that you can disconnect one cable at a time which should reveal a "black section" as a result... from there you can determine which cable is associated with the black line. I think that's how it works.Comment
You know i wanted to do that but the problem is i have heard bad things happening when you unplug stuff with a high voltage plasma.Comment
that's true but I think it depends. In this case, it would be no difference than an improper plugged cable. Anyway, you are getting / going to try another buffer card which is fine. The test (of unplugged cable) is so that you can understand which cable may be an issue and then focus your attention very close on that area). Based on my limited experience, the black line is the result of no signal making it down that "section". As you have tried (and others suggested, some get lucky) find reseating is necessary. From my limited experience (mostly LCD but does apply), this is a very "delicate" operation in terms of alignment / seating.... misalignment does happen among other things. Hopefully your replacement will solve the problem.Comment
Just a little update swapped in the new board to only have it still have the same issue, damn that sucks. I guess i will have to deal with a black horizontal line now. I also reconnected all the x-main connections and nothing. I had a lot of faith in plasmas but now i know why everyone hates these things. I'm just going to sell the boards on ebay and make back some money now.Last edited by Super360; 03-28-2020, 08:43 AM.Comment
I think you should try narrow down which connector the line is associated with. It might help.... maybe as then you may be able focus a bit more on that part of the connector.
Its too bad ... I like my two plasmas (both 50, panasonic and samsung).Comment
I have tried reconnecting this damn thing 50 times, putting pressure on it everything. It's obviously in the panel traces or something. It only has 1 small horizontal line so i will use it until more lines show up and then part this beast out. It's a damn shame for a 10 year old tv, the picture quality is amazing in my opinion.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by IhandyrepairHi guys
I just started fixing 4k TV few months ago. so I am still learning a lot
I got this tv from friend complaint is ghosting or horizontal lines on image.
never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
then it started to show the ghosting white image.
I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
it has 3 thin small boards at the bottom of the... -
by cubytusHi to all,
I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...1 Photo01-10-2024, 01:26 AM -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board... - Loading...
