PN50C590G4FXZA Horizontal Solid Black line
  • Super360
    • Jul 2016
    • 243
    Re: PN50C590G4FXZA Horizontal Solid Black line
    https://www.youtube.com/watch?v=DSi9EtmFIuo I think that's whats wrong with my screen but is it possible to just scrape away some of the ribbon cable and repair the trace or no?
    • budwich
      • Jul 2015
      • 3097
      could be....that's why I was asking you to do the "cable disconnect test" so you could readily determine which cable is responsible for which portion of the screen and then you could focus close on that on based on where the line was versus the "whole black" band that will appear when no cable is attached. Then, like the video you can look really close to see what the issue might be.
      One other point, once you start looking closer at the ribbon in question. Remember that I asked if you check the "other side"... that was the other side of the panel... which there are corresponding cables running along there also.
      • Super360
        • Jul 2016
        • 243
        Thanks for replying budwich im bout to dive really deep into this thing now. I just can't stand this stupid black line, Thanks again. I will take your advice and see which connector that i pull out corresponds to the black line.
        • Super360
          • Jul 2016
          • 243
          Ok so now i can officially say i've done everything to try and fix this thing. I took the screen apart from the bezel and i found out which line was related to the connector by budwhich advice. I then soon realized that both sides looked fine, there is no damage to be seen like no burnt traces nothing. This must be just a bad panel. I hate when there is literally no way to fix something but when it comes to the actual tv panel itself there is no way.
          • budwich
            • Jul 2015
            • 3097
            Have you checked the cabling on the other side of the panel???
            • Super360
              • Jul 2016
              • 243
              yes i did there was no issues i could see, even if there was there is no way to attempt a trace repair unless its on the ribbon even then it would be very difficult. The way these plasma are setup the ribbon is pressed between the glass and the panel connection creating a connection.
              • budwich
                • Jul 2015
                • 3097
                maybe you are right.... but I think you are giving up too. Who says the problem is in the cable. The cable connector at the other end (ie. board end) has to come from a track somewhere on the board, that may be fixable. See if you can see anything there. maybe post a close up picture of the area to give us an idea of what you are up against.
                • Super360
                  • Jul 2016
                  • 243
                  Dude i appreciate the shit out of you helping me out but i have taken this thing apart like 3 times and messed with it for hours. I more than anything want this to work but i am 99% its either where the ribbon goes into the actual panel(unfixable) or the panel is starting to fail. One thing i forgot to mention was i kept this thing on like 24/7 playing rainfall on youtube because i like the ambiance of rain. That probably led to the death of this poor thing. I have taken out all the x-main connections and the y-main cleaned all out with rubbing alcohol. No effect i also would tap on both the x-main and y-main several times with a screwdriver to see if it would flicker from a connection issue... nothing. I don't know what else i can do other than come to the conclusion that this screen is done for.
                  • budwich
                    • Jul 2015
                    • 3097
                    no problem... may it rest in peace... or should I say pieces. :-)
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • cubytus
                      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                      by cubytus
                      Hi to all,
                      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                      01-10-2024, 01:26 AM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
