Panasonic 65fx700b intermittent tcon problem
  • diif
    replied
    Re: Panasonic 65fx700b intermittent tcon problem
    It's not Nvidia chips exclusively BUT I didn't think you would grasp that EITHER and they die a lot more than occasionally, that's why reballing and reflows are not working per your bad advise in this case, which the chip wasn't even the problem.
    My experience of reflowing and reballing is clearly much much larger than yours and yes, Louis is talking exclusively about nvidia chips and why it's pointless reflowing/reballing those. He has little experience with consoles or TVs, which definitely do benefit from reflows/reballing. And from personal experience I can say that the BGAs fail far more then the chips.
    I'm not sure how you can clam it wasn't even the problem in this case, OP did a reflow that lasted a short while, I'm guessing it wasn't a very good one (no offence OP).
    replied
  • diif
    replied
    You are WEAK, as is your arguments, It is a very good thing that you did not become a defense attorney, they are bga chips, the end.
    I didn't think you would understand the difference. The Nvidia chips he talks about were from a specific time and suffered from faulty engineering, he is totally correct in that respect, "Bumpgate" is well documented.
    As far as I am aware he doesn't repair TVs or consoles that have all suffered from cracked solder joints of the BGAs due to repeated thermal cycling or from tin whiskers causing a short. Occasionally the chips do die, probably from heat but the majority have been fixed with reflowing or reballing.
    replied
  • diif
    replied
    For those that think a reball is always the answer AND don't presume to tell me you know MORE than Louis Rossman: https://www.youtube.com/watch?v=1AcEt073Uds
    There's a very big difference between faulty Nvidia chips and a failed/cracked bga.
    replied
    replied
    Nice fix, glad you didn't waste money on a reball, thanks for followup.
  • Michaelrobbo
    replied
    Heres a picture on what it would do after the TV would warm up you then turned it off and on and then it would work this will fix this problem models also effected are 65fxw724
  • Michaelrobbo
    replied
    Finally managed to sort this if anyone has the same problem you order a tcon for the 55fx700b 6871l-5478a and your remove 2 sets of caps from the board will put the numbers up tomorrow then use a ch341 programmer to read the epprom of the previous 5491a board and flash it to the new board or just do a chip swap with 24a32 epprom on the board. Now the TV runs great known issues with this model of TV and the tcons are near impossible to get hold of
  • Michaelrobbo
    replied
    Do you know anyone in the UK that could do it and how much? Reakon I'd do any damage swapping the tco. With the 55 inch model maybe if I swapped the epprom chip over of the old one if all the other parts match uo
  • diif
    replied
    If a reflow fixed the tcon for a month, reballing it should fix it permanently.
  • Michaelrobbo
    started a topic Panasonic 65fx700b intermittent tcon problem
    Bought the TV about a month ago faulty as it would take about an hour to turn on turns out it was the tcon board as with a reflow has been working great for a month but now the problem is returning upon looking for a replacement there are none on the Internet looked everywhere the only board I can find close is for a 55fx700b which has the same sub model which is a 6870C-0757A but a different main part number mine is a 6871L-5491A and the one for the 55fx700b is a 6871l-5478h anyone had any joy in swapping theses or repaired the original board any help would be appreciated
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • hugocarmo
    Panasonic TX-24A1UN CRT Sound and Input problem.
    by hugocarmo
    Hi.
    I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
    It is imaculate inside, almost no dust or debris inside.
    The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
    So I started to look for a service manual, I found one, and started from the beginning.
    Most of the times the caps are the problem so I orderer all the caps for all boards,...
    04-26-2025, 07:45 PM
  • renech
    panasonic TH-42PC77U plasma television half screen problem
    by renech
    hello,
    I hope someone on this forum can assist me.
    I have a panasonic TH-42PC77U plasma television.
    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
    I have read some posts that suggest the problem is related to the boards on the left...
    12-12-2022, 06:53 PM
  • Vebririon
    panasonic TX-P50V10E 6 blink led problem
    by Vebririon
    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
    05-17-2025, 10:16 AM
