Hello everyone, I've had this TV for almost 6 months now, just sitting in the fix-it room and it would be great to get this finished up.
It sounds like the typical Vizio complaint….hit the power button, backlights flash, image on screen but no picture with sound…so what do I do? Order backlights from SJ without taking a single voltage reading. Apparently my “jaundiced eye” over-rode my need to do a diagnostic. This was a mistake.
Install SJ backlights….problem still exists. Check all connections and connectors….no happy. When the backlights flash…they all flash….as if to say “way to go dummy”. Rows 2 and 3 of the LED strips are noticeably dimmer than the others tho.
So how about some voltage readings?
CN201 (to main board)
Pin#.....Function....Volts (tv off)….Volts (tv on)
1...…….+18Vsb...….15.48......……...18.07
2...…...+18Vsb...….15.48.........…..18.07
3...…….+18Vsb...….15.48...………….18.07
4...…….GND
5...…….GND
6......…GND
7...…….PS-ON......…0.........….........3.21
8.........BL on/off.....0.........…………..3.15
9. BoostLEDCkt…… .12............……..3.10 flash, drops to .04
10...…..PWM1...…….0.........…………..2.74 for 3sec, drops to .75, drops to 0
11...…..PWM2........0............………..2.74 for 3sec, drops to 0
12...…..PWM3...…...0...……...………...2.74 for 3 sec, drops to .7, rise 1.66, trails off to 0
13...…..PWM4...…..0............………..2.74 for 3sec, drops to 0
14...…..PWM5...…..0............………..2.74 for 3sec, drops to .75, drops to 0
CN301 (BL connector)
1...…...LED1+...…..31.5...……………..40 to 90.3 to 40.7
2........LED1-...…….0...............…….38.2 to 3.7
3...…...LED2+...…..31.5............…..40 to 89.7 to 40.7
4...…….LED2-...…...0...............…….43.1 to 3.7
5...…...LED3+...…..31.5...…...……….40 to 88 to 40.7
6...…...LED3-...…...12.8............…..15 to 34.6 to 14.9
7...…….LED4+...…..31.5............…..40 to 89 to 40.7
8...…….LED4-...…...12.8...……………..15 to 38.1 to 14.9
9...…….LED5+...…..31.5............…..40 to 88.3 to 40.7
10...…..LED5-...…...12.8............….15 to 38.1 to 14.9
What I see looks like either a PSU with something wrong in the LED boost circuit or a Main Board not outputting the correct PWM value to the PSU.
What do you think guys? Is the PSU or the Main Board the culprit here?
Pictures posted! Thanks everyone!
4...…….GND
5...…….GND
6......…GND
