LG 50PK950 - No image shown
  • Warner
    • Mar 2020
    • 12
    • Italy
    My Plasma TV broke down today. When turning it on (with either with the remote or the touch-screen buttons), the screen lights up as normal (meaning it's lights up first and then becomes almost black but visibly light in a dark room), but no image is shown.
    I've tried removing all the inputs, removing the power for a while, and now I'm looking inside.
    - The controller board led is flashing 'long-short-long-short'
    - With the main board disconnected there is no difference in the behavior (no test patterns or anything)
    - With the main board disconnected, the controller board is still flashing 'long-short-long-short'
    My thought is it must be the main board.. (I read several threads with similar issues).
    What I can see is the attached picture, which looks to me like a broken capacitor, but I don't have so much experience. Can anyone have a look and give me their opinion? What could I measure to verify this is the cause?
  • Warner
    • Mar 2020
    • 12
    • Italy
    Re: LG 50PK950 - No image shown
    Here's a picture of the full backside for reference
    • R_J
      • 9625
      With the tv unplugged, locate the control board, (just below the power supply) and unplug the cable (P31) that goes to the main board. On the control board there are two points (lower right corner) connected to R51 & R52. you need to place a short across those two silver points and plug the tv in. This should generate test patterns on the screen. If they are ok, the fault ison the main board
      That cap does not look bad, was something spilled on the tv, it looks more like water damage.
      • Warner
        • Mar 2020
        • 12
        • Italy
        Ok, did that. Indeed, when connecting those two points I'm getting test patterns.
        So what could I try now? Any tests to do on the main board?
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Classis symptom of failed solder joints on the processor of this main board (chip under the black heat sink). You'll need to have it serviced or replace the board.
          • Warner
            • Mar 2020
            • 12
            • Italy
            Yeah I was afraid it would be beyond my capacity to repair.. They are really hard to find though in Europe (and I can't find a servicing company on this continent either).
            No way to try and fix this myself? Heat up the edges of the chip so the solder melts back?
            • R_J
              • 9625
              I don't know what to tell you to check, That cap you mentioned in in thge audio section so I doubt it is the problem. It could be a BGA connection problem on the large ic under the heatsink. Try heating the board and large ic with a hairblower/heatgun and see if it makes a difference.
              • Warner
                • Mar 2020
                • 12
                • Italy
                Okay, getting ready for some heat
                • Warner
                  • Mar 2020
                  • 12
                  • Italy
                  Well.. there was not much hope, but indeed it didn't work.
                  The only replacement board I can find is of an LG 60PK950 (same model, larger version). Do you think that could work or will I get problems with the wrong firmware and so on?
                  • Warner
                    • Mar 2020
                    • 12
                    • Italy
                    Update!
                    So I tried once again and the the screen came back... but not exactly as we were hoping. Screen is all red and dancing around.
                    I guess now we can really throw the main board.. Unless anyone has great ideas
                    • Warner
                      • Mar 2020
                      • 12
                      • Italy
                      Update!
                      Okay.. wait a minute.. Is it possible that I accidentally repaired the board but broke the cable?
                      Now I need your help again... . Does anyone know any tricks to repair a cable like this?
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        Yes, that's definitely the problem now. Also, what did you use to heat the board? If it wasn't hot enough, the issue will problem resurface quickly. As far as the cable goes, you'll almost certainly need a replacement.
                        • budwich
                          • Jul 2015
                          • 3097
                          what the hell happened to that????? Surely you didn't heat the board with all the "things" attached.... :-(
                          • Warner
                            • Mar 2020
                            • 12
                            • Italy
                            Nonono.. of course not.
                            I just messed up pushing the cable back in without close attention.
                            Ordered a new cable - should arrive in a few days.
                            • R_J
                              • 9625
                              You did'nt release the latch on the connector and just tried jamming the cable in. You must release the latch or this will happen with your new cable as well.
                              • Warner
                                • Mar 2020
                                • 12
                                • Italy
                                Okay, an update:
                                - new cable ordered
                                - the heating of the main board worked, but only for a little while. The next morning we were back where we started
                                - found a main board with a different number (EAX61141606(0) instead of EAX61141603(4). It belonged to another 50PK950. There is a slight difference in the layout just by looking at it. Can it be an updated version from later production that works just as well?
                                So the question is: Will This Work??
                                • R_J
                                  • 9625
                                  There is a connector missing on the (606) board, which is used on your's and likely other components not populated
                                  • Warner
                                    • Mar 2020
                                    • 12
                                    • Italy
                                    Oh darn, thanks so much.. I totally missed the connector there. Okay, that's no good then.
                                    • Nick's Tvs
                                      • Jan 2014
                                      • 621
                                      For the American versions of these boards, they are cross compatible between the 60 and 50 inch models. As well even with several connectors missing on one board vs another you will still get the TV to work. A lot of the times those additional connectors are for higher end modules with additional options such as a connector for a wifi module or a Bluetooth module. If you purchase one of these boards without that connector, you may loose the ability to plug in your Wifi module or your Bluetooth module. If you don't use those features anyways then go ahead and get that board as a replacement. If you aren't sure what that connector goes to, then simply follow the cable to which ever board it plugs into and look up that part number to find out if it is your bluetooth, wifi or other.
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
                                      • ygorsan
                                        by ygorsan
                                        🧩 Problem Summary:
                                        • I
                                        07-28-2025, 08:34 AM
                                      • tuner2000i
                                        Philips 65PUS8518/12 distorted image after main board replacement
                                        by tuner2000i
                                        hello everyone,
                                        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                        07-15-2025, 01:15 PM
                                      • jb_Bak
                                        by jb_Bak
                                        CN6401
                                        Pin 01 NC
                                        Pin 02 NC
                                        Pin 03 "BL_ON": 0V
                                        Pin 04 "N/C"
                                        Pin 05 "STBY 3.3V": 3.5V
                                        Pin 06 "GND": N/C
                                        Pin 07 "AC_OFF"...
                                        09-27-2021, 04:52 PM
                                      • JDC
                                        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                        by JDC
                                        ONN 100012588
                                        Issue: No Power, Then Rebooting After Main Board Change
                                        Short answer: replace main board and power board
                                        Technical answer: replace main board and Q306 & Q307 on power board.
                                        Long answer:
                                        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                        07-15-2022, 07:39 AM
