Hi all, I have a 2006 NEC PX-42XR4G monitor with a pioneer plasma display that I have recently taken out of storage and all was fine for around three hours then the set went into standby and refuses to power up ? I have taken the back off and I have a red surface mount LED on the digital board flashing six times ! The caps on the PSU board look fine and none appear to be excessively bulged or leaking ! I want to repair this display as it has a VGA port for my desktop computer and one HDMI port for my PS3 and blu ray player !
NEC plasma monitor stuck in standby
by XConSymptom is TV has standby, I get relay click, voltage rails come up, but no screen and TV shuts down after 5 seconds. If I disconnect the Z from the y sus, the unit stays powered up and I can read voltages.
So I've read the two other threads on this TV and I can confirm the Y-Sus #EAX64789501 does not have diode or resister failure. Did not see any fractured solder joints on the transformer or anywhere else. All power boards have slight discoloration on the hot spots.
The board in question is EAX64789601, Z board. I have 208 going to Y Sus, 5v standby. Pin 5 on P174 connector... -
by lepak06Hello
I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
The TV is faulty with stuck in Standby RED LED. Can't power the TV.
Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power... -
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by toty79Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
As per Hisense tv title LTDN50K220WSEU stuck in standby
PSU rsag.820.5687 HLL 4855WF
Main rsag 7.820.5842
I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages... -
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
- Loading...
