SONY XBR-65X850A Won’t turn on
    Re: SONY XBR-65X850A Won't turn on
    https://www.badcaps.net/forum/attach...5&d=1582213154
    According to the chart, you will report in this format (Notes that the connector CN6401 has Even pin column and Odd column pin. Even column pins you can probe from the top side of the board, the Even number pins you will have to probe from the bottom side or use skinny probe on the wire entrance side).
    When TV is Off:
    Pin 1 NC = No connection
    Pin 2 DIGITAL_STBY = ??? V
    Pin 3 BL_ERR = ???? V
    Pin 4 ......
    When TV is turned on:
    Pin 4 ......
    • Slavabusy
      • Jan 2020
      • 31
      • Usa
      Originally posted by Slavabusy
      No any dc voltages outputs from power boards. Instead, some pins showing around 3v A/C.
      In order left to right:
      Plug cn6601 all zero volts
      Plug cn6602 all zeros
      Plug cn6402 all pins except #1 measured 3vac, #1-zero volts
      Plug cn6401 (from top to bottom)
      Pin #2 measured 3vac, all other pins 0 volts
      Input voltage is 120vac at both of the power boards, fuses are good.
      Any ideas appreciated!
      Please DISREGARD this post, my mistake.
      • Slavabusy
        • Jan 2020
        • 31
        • Usa
        Board G6, connector CN7401:
        Pin 25 STBY3.3v = 3.4vdc
        Pin 27 AC_OFF_DET = 3.4vdc
        Also I checked STBY FB (top left corner of board) 3.3vdc on D6201 Cathode (white mark on diode)
        3.4vdc is present at the Cathode of D6201.
        No other pins of any other power boards connectors showing voltage.
        Will take pictures of the back of the power boards tomorrow.
        Thank you all guys for participating it this repair thread!
        • R_J
          • Jun 2012
          • 9627
          The power supply will not show other voltages untill it sees the PS_ON signal from the main board. Check this pin and press the power button, does this voltage change? if not I suspect the fault is on the main board.
          • Slavabusy
            • Jan 2020
            • 31
            • Usa
            Thank you! Will do in the evening!
            • budwich
              • Jul 2015
              • 3097
              You are likely doing your measurements "too late". You need to monitor the voltage on a pin when you attempt to turn the set on as the system shuts things down pretty fast IF it detects a problem. Further, you didn't follow the "good advice" provided in post 21 that you had asked for.... :-( Following this advice will give that forum a better feeling that you measuring "work" is being done correctly.
              • Slavabusy
                • Jan 2020
                • 31
                • Usa
                #27
                That is correct! I didn’t even try to turn it on, because it doesn’t turn on..
                  Originally posted by r_j
                  the power supply will not show other voltages untill it sees the ps_on signal from the main board. Check this pin and press the power button, does this voltage change? If not i suspect the fault is on the main board.
                  +10
                  • R_J
                    • Jun 2012
                    • 9627
                    You can test the power supply by disconnecting the plug on CN6401 that goes to the main board. Then use a (about) a 1k resistor, and connect it between STBY3.3V and POWER_ON
                    (or between D6201 Cathode [white mark end] and JW6134 (next to cn6401)
                    This shouldl turn on the REG12V.
                    • pier12
                      • Feb 2020
                      • 19
                      #30
                      Look at page 105 in this service manual
                      • Slavabusy
                        • Jan 2020
                        • 31
                        • Usa
                        #31
                        You guys are awesome! Thank you all! Sorry, didn’t have a chance to test any yet, but I will do soon!
                        • Slavabusy
                          • Jan 2020
                          • 31
                          • Usa
                          #32
                          When I press power button
                          Pin 28 (POWER_ON) voltage doesn’t change, 0v
                          I didn’t have a 1kOhm resistor to kick on the power boards.
                          Pier12, this is nice repair manual, but not sure if it covers 100% of the model I have because I couldn’t find JL9129 or any JLs on the main board.
                          But, I ordered main board from tvpartstoday.
                          Hopefully, it’s gonna make it!
                          Fingers crossed..
                          • R_J
                            • Jun 2012
                            • 9627
                            The resistor does'nt need to be a 1k, usually between 470Ω to 2~3k should work. But since you don't have the POWER_ON signal from the main board, that is more likely the issue. If it was a fault on the power supply (and you have standby voltage to the main) you should see the POWER_ON go from 0 to 3 volts when you push the power button.
                            • Slavabusy
                              • Jan 2020
                              • 31
                              • Usa
                              #34
                              Thanks.
                              • Slavabusy
                                • Jan 2020
                                • 31
                                • Usa
                                #35
                                Finally, I have some progress.
                                First replacement main board didn't do anything, but they were nice and sent me another one.
                                Now, tv turns on and I can see the menu and navigate there.
                                However, it doesn't go online for any apps, or updates.
                                Status is showing connected, ip, and all that.
                                Both boards they sent me are used, I think.
                                • Slavabusy
                                  • Jan 2020
                                  • 31
                                  • Usa
                                  #36
                                  Using wired connection directly from my router
                                  • jrodefeld
                                    Sony GDM-FW900: Help me diagnose why it won't turn on? (Video included)
                                    by jrodefeld
                                    I have a vintage Sony GDM-FW900 crt monitor that I really enjoy using, but it has developed a problem and won't start up.
                                    This unit was completely serviced a few years ago by Unkle Vito in Los Angeles and it fully passed all tests, was factory calibrated, etc. There was a faulty part (can't remember exactly which one) that was replaced at another repair shop about a year ago. Other than that, it's been working great.
                                    I just say all that to say that this unit is probably in pretty good shape since it's been fully serviced and checked recently....
                                    03-03-2023, 09:51 PM
                                  • Abel Bejan
                                    Sony Vaio does not turn on, overheats
                                    by Abel Bejan
                                    I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
                                    Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
                                    01-11-2025, 10:11 AM
                                  • odie34
                                    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                    by odie34
                                    I am a hobbyist (not a professional) so please be gentle...
                                    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                    02-18-2024, 09:11 AM
                                  • pajdek
                                    Lenovo Y700-17ISK turn on and off
                                    by pajdek
                                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                    09-20-2023, 02:49 AM
                                  • Zetabeta87
                                    Sony KD-49XF809y doesn't turn on
                                    by Zetabeta87
                                    Hi everyone!
                                    I have a 2018 Sony kd 49XF8096 that suddenly stopped turning on: No LED lights up, and it doesn't respond to the power button or the remote control.
                                    The power supply delivers 19.45vand I simply tried to check the fuses on the 2 boards (power and main) but everything seems ok. I have no references on where to test the voltage, but somewhere on the mainboard I also detect some, so you can't to understand which card may be to blame.
                                    Can anyone give me some advice? I haven't found anything online
                                    Thanks so much!!!
                                    11-04-2024, 03:18 PM
