In addition to 2 flat-screen TVs, I own a 27" CRT (reliable!) TV (JVC AV-27750), connected to a Converter Box. A few days ago, its IR sensor stopped working. It does not respond to any button of the Remote Control. The remote control works fine (I can see it flashing through a cell phone's camera), and a capacitor and a resistor near the IR sensor have the correct values. I desoldered and removed the IR sensor from the small Front Control CB. It has a metal cover -- please, photos. It has two numbers on the metal cover: HC-337M (which the Service Manual identifies as the part number and) 33N643.
1st Question: Does anybody know where I can buy a replacement IR sensor? I have searched for a long time and found nothing.
Also, as I look at the TV standing in front of it, the 3 pins of the IR sensor are identified and labeled in the Service Manual, form left to right, as follows:
Pin 2 (the leftmost pin): Out 4.2V
Pin 1 (the middle pin) : Vcc 4.9V
Pin 3 (the rightmost pin): GND
2nd Question: Is the above pin information useful for somebody to help me find a compatible replacement IR sensor, if the OEM is no longer available?
3rd Question: Does anybody know at which frequency this IR sensor (and, of course, the Remote Control itself, RM-C742) operate?
Additional Information:
1. Before removing the small front control board, on which the IR sensor is also mounted, and while the TV was plugged in an AC outlet, I measured the voltage between pins 1 - 3 and I found 5.0V. So, the IR sensor receives power.
2. The part # of the entire Front Control CB is: SGK-4011A-M2. I cannot find this part either.
It's cold here at times in Canada, but not that cold!
Easy solution is to go to AcuRite website and purchase the sensor. Right?...
