JVC AV-27750 IR Sensor Problem
  • NewAtThis
    • Jun 2019
    • 22
    • U.S.A.
    In addition to 2 flat-screen TVs, I own a 27" CRT (reliable!) TV (JVC AV-27750), connected to a Converter Box. A few days ago, its IR sensor stopped working. It does not respond to any button of the Remote Control. The remote control works fine (I can see it flashing through a cell phone's camera), and a capacitor and a resistor near the IR sensor have the correct values. I desoldered and removed the IR sensor from the small Front Control CB. It has a metal cover -- please, photos. It has two numbers on the metal cover: HC-337M (which the Service Manual identifies as the part number and) 33N643.
    1st Question: Does anybody know where I can buy a replacement IR sensor? I have searched for a long time and found nothing.
    Also, as I look at the TV standing in front of it, the 3 pins of the IR sensor are identified and labeled in the Service Manual, form left to right, as follows:
    Pin 2 (the leftmost pin): Out 4.2V
    Pin 1 (the middle pin) : Vcc 4.9V
    Pin 3 (the rightmost pin): GND
    2nd Question: Is the above pin information useful for somebody to help me find a compatible replacement IR sensor, if the OEM is no longer available?
    3rd Question: Does anybody know at which frequency this IR sensor (and, of course, the Remote Control itself, RM-C742) operate?
    Additional Information:
    1. Before removing the small front control board, on which the IR sensor is also mounted, and while the TV was plugged in an AC outlet, I measured the voltage between pins 1 - 3 and I found 5.0V. So, the IR sensor receives power.
    2. The part # of the entire Front Control CB is: SGK-4011A-M2. I cannot find this part either.
    Re: JVC AV-27750 IR Sensor Problem
    Did you look at the output pin with the scope?
    Spec of similar HC series.
    • NewAtThis
      • Jun 2019
      • 22
      • U.S.A.
      Thank you, budm, for the fast and informative reply. I cannot understand all the information in the pdf file (I am a beginner), but the HC-337M is there! The data sheet lists its frequency as being 37.9 kHz. Does anybody sell this IR sensor?
      In response to your question, I do not have an oscilloscope to look at the output pin. Before removing the Front Control CB, on which the IR sensor resides, I tried to measure the output voltage with a DMM while the TV was on, but I heard scary click-click sounds, as if I was causing a short somewhere! I stopped immediately. From the fact that the TV was still working after that, except for the IR sensor not responding to the Remote Control, it appears that I did not cause a new problem. But that scared me enough not to try anything else.
      • NewAtThis
        • Jun 2019
        • 22
        • U.S.A.
        Just an idea: Does anybody know, if I were able to find an IR sensor that operates at the same frequency as the one of my TV and has the same Vcc and Vout voltages, would I be able to use it without the tiny CB and metal housing of the original IR sensor (shown in photos posted earlier)?
        • piipo
          Old Privileg 5.1 speakers remote control question
          by piipo
          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
          09-18-2024, 01:55 AM
        • crackedprint
          Sony HCD-HX80R Amplifier Volume Control Problem
          by crackedprint
          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
          I have tried a Cold Reset as per the service manual.
          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
          I have looked all the way through the service manual and tried many online...
          01-21-2025, 12:18 PM
        • CapLeaker
          AcuRite 5 in 1 temperature sensor replacement repair
          by CapLeaker
          Got a new victim:
          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
          B: stuck at some temperature and maybe updating once in 12 hrs or so.
          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
          04-15-2025, 01:32 PM
        • harp
          simple 24v fan control problem
          by harp
          I am working on automated fan speed for lab psu... the fan is 24v 0.15A, and I am connected it to 820 ohm to ground, that provide minimum silent air flow on startup. It is powered around 4v at minimum point. Parallel to resistor I connected BD139, that drive a 10k NTC. Everything work like expected, but in extended test, where I isolate NTC, I have few issues, and like to ask here for help. 1. If ntc is not connected to heatsink, it go slowly to heat up and up and fan make noise than... At point "A" I measure voltage and put NTC in flame, everything is working ok till about 1.1v, and...
          10-09-2025, 03:20 PM
        • Jackching
          Hisense 65R6107 remote sensor
          by Jackching
          Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
          10-30-2023, 11:35 AM
