Kdl-70w830b sim in middle of picture after backlight repair
  • jeffer76
    • Sep 2011
    • 76
    • US
    Re: Kdl-70w830b sim in middle of picture after backlight repair
    Originally posted by mmartell
    If it has the same properties on both sides of the sheet take it out and flip it over. If you bowed it in one direction flipping it over might help to restore its properties.
    Are there any plastic spacers beneath the sheet to keep that layer from sagging ?
    I tried flipping the sheet over. Bottom side is slightly different. No change.
    No plastic spacers.
    • jjanssen7
      • Nov 2012
      • 252
      Still curious about this... I have a Samsung UN55F8000 (that has never been apart) that has the same issue. I'm wondering if anyone knows if the diffuser sheets can get old or distorted and not transfer light the way they originally did? In my case it's possibly due to age, in the case of this thread it is possibly from bending?
      Other long-shot... jeffer76, Did your diffuser spend any time in direct sunlight while the TV was disassembled? I'm wondering if the TV I have (I have no history on it) spend time in the direct sunlight which changed the property of the diffuser sheet.
      • saddle_au
        Waste Warrior
        • 121
        Bow in the sheet or incorrectly positioned sheet. Last time I saw something like this, it turned out there is a slight angle of entry for the leds into the edge of the sheet. The light doesn't seem to bounce it's way through the sheet like it should. The sheet was slightly off centre and it was pressing hard on the leds.
        If you can place the sheets flat on a desk, shine a led torch into the edge and see if you still get the same darker area in the middle. You'll have to do this with the lights turned down because a led torch isn't as strong (normally). I use one of those powerful cree torches for this job when I'm trying to clear water marks (yes you can clean these out). Worst thing to do is to crease the sheet when moving them around, the sheet becomes a throwaway. I keep sheets and leds from busted screens as replacements, takes a while to get them out neatly. Doesn't take much room to stack lots (like those poster racks at a cinema with supporting cardboard between them).
        • Pooshoes
          • Mar 2022
          • 12
          No plastic spacers.
          I have the same issue with a kdl-70w840 tv but it had a BL error blink code so i bypassed it and had bright edges like you. I replaced lights with new strips and no improvement. I replaced the LED driver board with no improvement. Unplugged Tcon and no improvement in LED output. So power supply or mainboard error is the culprit. Did you happen to solve your problem? @jeffer76
          • Pooshoes
            • Mar 2022
            • 12
            Replaced power supply and mainboard and the same issue persists. Maybe i replaced the led driver board with another faulty one?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4463
              • Italy - Milan
              #26
              What the hell of a repair technique is this?? Changing boards brainless without even check if the leds are evenly lighted up? Disaster...
              • nomoresonys
                • 12276
                • U.S.
                #27
                Looks like a lot was tried, thinking it must be how the sheets are going back in, everything needs proper spacing, if there was standoffs, they need to be put back.
                • burbutsalos
                  LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
                  by burbutsalos
                  Hello everyone.
                  I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
                  The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
                  The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
                  The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
                  The effect is there even on a completely black screen.
                  The screen...
                  10-21-2023, 02:57 AM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
