Please help, is my Panasonic plasma ZT65 dead?
  • HumanTT
    • Jan 2020
    • 11
    Re: Please help, is my Panasonic plasma ZT65 dead?
    Originally posted by linksys1127
    Looks like your SC board or the board on the left is bad. 900 ohms is way too low. You'll probably find some of the ICs mounted to the heatsinks shorted. You can also check the SD and SU boards for shorted buffer ICs. Those are the boards that are mounted between the flat ribbons that go to the panel and the left board. Here's a link to a video on how to do that.
    https://youtu.be/-JVLWpcIxJQ
    Ok I will test it tomorrow, just to rule them out. Thanks for posting a video of the test you asking about, it makes following along easy lol.
    • R_J
      • 9588
      Originally posted by HumanTT
      I believe a plasmas has 3 sheets of glass, but I could be wrong. The front glass that you can touch has a IR filter on it, and then you have two sheets of glass that have the gas in-between them that is sealed. I don't believe you can see the back glass.
      Edit
      https://video.nationalgeographic.com...c-7b3d9d680000
      https://www.youtube.com/watch?v=YlS24yOZZSk
      That front sheet of glass was used on some of the older plasma tv's, some early 42" Panasonics and other brands had them, but most of the newer plasmas did'nt. The glass you could touch was the actual plasma panel.
      The best way to check the SS and SC boards is when the tv is powered on, then you can check the Vs voltage. Checking the resistance across the Vs pins won't tell you much unless it is shorted. It would be like measuring the resitance across the AC cord to find a problem on the main board in the tv.
      • linksys1127
        • Sep 2016
        • 121
        Thank you for clearing that up R_J. I was steering you wrong HumanTT sorry about that. I've obviously got a lot to learn about plasmas and the folks here are experts. The defect you have wouldn't be a bad buffer board. That would be a defect that would run from one side of the screen to the other so your buffer boards are probably ok.
        • badcappo
          Dead Panasonic Viera TX-P65STW50 Plasma TV
          by badcappo
          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
          Diode type G972s6 - D101 with a short
          Mosfet 06N90E - Q301 shorted
          Fuse T5AH 250V - F103 blown
          Diode D301 shorted
          Relay DG1U-17VDC II - RL001 blown
          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
          11-24-2024, 11:27 AM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
