sharp lc32d42u power supply - DPS-178APA
  • metropical
    • Jan 2017
    • 42
    Re: sharp lc32d42u power supply - DPS-178APA
    Took some doing but there is always a piece of sacrificial Cat 5.
    I took a piece of wire from ground to the Q7907 collector.
    With TV on or off, 5v.
    So Q7926 is good?
    • R_J
      • 9628
      So with the the wire on Q7907, you get 5 volts on J7915. I can't see what would be preventing the 5 volts for the panel from turning on, Try disconnecting the LVDS cable going to the t-con board, then with plug PE re-connected see if you get 5 volts on J7915
      • metropical
        • Jan 2017
        • 42
        which is the LDVS cable? The 2 ribbons at the top of the board or those at the bottom behind the cage.?
        Also, not familiar with those connectors. How do they separate?
        • R_J
          • 9628
          The lvds cable is the one between the main board and the t-con board, it must be behind shield, It is the wide 30 pin, You can also just unplug it from the main board.
          • metropical
            • Jan 2017
            • 42
            both sides behind the cage.
            Ov.
            • metropical
              • Jan 2017
              • 42
              Hi R_J. I realize you're prolly have other things going, but when you get a chance.
              Thanks,
              Fritz
              • R_J
                • 9628
                Ov.
                Remove the shield to gain access to the t-con board.
                • metropical
                  • Jan 2017
                  • 42
                  zero volts on J7915 with plug PE restored and the lvds unplugged.
                  • R_J
                    • 9628
                    That eliminates the t-con/panel, killing the voltage. Look for IC2007 on the main board, this is the ic that controls the PNL5V_ON, I was going to say post the voltages of the 5 pins, but it seems to be a bga chip.
                    So check the voltage on R2004 and C2024
                    • metropical
                      • Jan 2017
                      • 42
                      IC2007, R2004 and C2024 seem to be on the B-side (trace).
                      Are there test points on top I can access?
                      • R_J
                        • 9628
                        If you look at the service manual, it has board views, you would need to follow the trace and see where it appears on the other side.
                        • metropical
                          • Jan 2017
                          • 42
                          trying to figure out the location.
                          Is there any indication in the SM pcb drawings that would indicate this heat sink. The ref point might help localize the chip.
                          Or remove it that I might have a look at whats hidden.
                          • R_J
                            • 9628
                            IC2007 pin1 is the PNL5V_ON_CPU and connects to [Y23] under the CPU.
                            IC2007 pin2 is the PNL_POW and connects to pin 63 of IC2002
                            Pins 1 AND 2 need to be high (3.3v) to get the PNL5V_ON (IC2007 pin4) to be high which turns on the panel power on the power supply.
                            Since the pins are hard to access I don't know how to check their voltages.
                            • metropical
                              • Jan 2017
                              • 42
                              Since I'm sure the PS is the problem, as when I swapped supplies with another of the same TV, it works.
                              Isn't there some point to source the problem on the power board?
                              • R_J
                                • 9628
                                What voltages are missing on the power board?
                                PE
                                pin1=UR6V
                                pin2=gnd
                                pin3=PNL5V
                                pin4=PNL5V
                                pin5=gnd
                                pin6=gnd
                                pin7=UR10V
                                pin8=UR10V
                                pin9=gnd
                                pin10=gnd
                                pin11=UR13V
                                pin12=UR13V
                                PD
                                pin1=PS-ON
                                pin2=AC_DET
                                pin3=gnd
                                pin4=PNL POW
                                pin5=BU5V
                                pin6=gnd
                                LA
                                pin1~5=24V
                                pin6~10=gnd
                                If the only voltage you are missing is on plug PE: PNL5V , short Q7907 collector to ground, this will turn on the PNL5V and the tv should work. If it does, the Q7907 could be bad.
                                • metropical
                                  • Jan 2017
                                  • 42
                                  PE
                                  pin1=UR6V - 5.77
                                  pin2=gnd
                                  pin3=PNL5V - 0
                                  pin4=PNL5V - 0
                                  pin5=gnd
                                  pin6=gnd
                                  pin7=UR10V - 10
                                  pin8=UR10V - 10
                                  pin9=gnd
                                  pin10=gnd
                                  pin11=UR13V - 12
                                  pin12=UR13V - 12
                                  PD
                                  pin1=PS-ON - 3.02
                                  pin2=AC_DET - 3.07
                                  pin3=gnd
                                  pin4=PNL POW - 0
                                  pin5=BU5V - 5
                                  pin6=gnd
                                  LA
                                  pin1~5=24V yes
                                  pin6~10=gnd
                                  when I short Q7907 collector to ground, the red LED annunciators on the Main panel under the heat sink/cage, go off.
                                  But the TV does not come on.
                                  • R_J
                                    • 9628
                                    The ONLY voltage that is not being supplied by the power supply is the switched PNL5V. This voltage comes directly from the working BU5V. The only control line for this voltage is PNL POW, It needs to be at 3.3 volts to turn on Q7907 base.
                                    Shorting Q7907 collector to ground will force the PNL5V ON. So if the main board etc. are ok, the tv should work.
                                    • metropical
                                      • Jan 2017
                                      • 42
                                      "Shorting Q7907 collector to ground will force the PNL5V ON. "
                                      Something has changed here. The blue power LED upfront no longer lights.
                                      I just shorted the C of Q7907 to gnd. PNL POW (P4 of PD) OV.
                                      P3/4 of PE at 0V.
                                      Perhaps Q7907 was failing or am I coming to the wrong conclusion?
                                      Other Voltages are all still correct.
                                      • R_J
                                        • 9628
                                        Disconnect the power supply from the main board and get two 1K resistors, Connect one resistor between BU5V and PS-ON and the other resistor between BU5V and PNL POW
                                        Then check if you have all the voltages including PE pin 3,4 PNL5V
                                        • metropical
                                          • Jan 2017
                                          • 42
                                          "Since all the other voltages are being supplied by the power supply, and you say the rest of the tv is working and the fault is on THIS power supply. Simply forcing on Q7926 will not be an issue and the tv will work because you tested proved it with the other power supply correct?
                                          Correct.
                                          Can I assume that this resistor test can be done without the "load" of the rest of the TV?
                                          If so, I'd bring it to my friends shop week after next and do it there.
                                          If not I'll get a couple 1ks from him and do under load.
                                          But thanks so far, R_J, and I'll be in touch after I visit his shop.
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
