faulty AY160D-4HF12 power board
  • galrock
    • Jan 2014
    • 10
    • israel
    I Have received a TV that someone worked on and removed the following components
    Q4, C27 and R41
    from the colors of R41 from photos online it is a 0.3ohm resistor but I can't find any schematic of the board online.
    Any help would be greatly appreciated
    posts mentioning the same board are
    https://www.badcaps.net/forum/showth...ghlight=ay160d
    and
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: faulty AY160D-4HF12 power board
    Q4 : 13N50
    R41 : 10Kohm
    • galrock
      • Jan 2014
      • 10
      • israel
      Originally posted by arizanotlari
      Q4 : 13N50
      R41 : 10Kohm
      thank you, any idea on c27?
      • R_J
        • 9580
        R41 can't be 10k it is 0.3Ω It is the fet's source resistor.
        • galrock
          • Jan 2014
          • 10
          • israel
          Also pretty sure from colours in photos that it is 0.3
          But can't figure out c27
          • R_J
            • 9580
            I looked a a few power supply schematics and the value for C27 could be around 20~220 pf and the originals are usually 1KV but its best to use a 2KV replacement
            Samsung board BN44-00338B uses a 12N50 mosfet and the cap from drain to hot ground is a 220pf/2kv so it might be similar
              What is the P/N printed on SMPS IC1?
              C27 is the snubber cap for MOSFET Q4, it is connected to Source and Drain of Q4, typical value is 220 ~ 330 pf 2KV.
              The application circuit of IC1 may show the value of snubber cap.
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                • galrock
                  • Jan 2014
                  • 10
                  • israel
                  Logo is of ST
                  From what I can read there is
                  L6562A
                  And
                  GZ344
                  But I can be wrong, will attempt to upload the best photo I can of the IC
                  • 4jx1nz
                    • Jul 2024
                    • New Zealand
                    Sorry to bump an old thread, but it might assist those who are in the same scenario.
                    I'm interested in resistor values:
                    r9
                    r10
                    r11
                    r12
                    r13
                    r14
                    or a high def / clear picture of the back of the board.
                    Thank you
