Sharp Aquos lc-70le650u - Hissing sound from main board
  • twikii
    • Dec 2019
    • 9
    I've got a pretty loud hissing sound that I think is coming from my TV's main board. This sound is constant and doesn't seem to change once the TV has warmed up. It is there when the TV is on and when it is in standby mode. The TV is working, but the noise is loud enough that I can hear it even when it is playing audio. Does anyone know what the issue is and how I might be able to fix it?
    Re: Sharp Aquos lc-70le650u - Hissing sound from main board
    Did you open up the TV and actually listen closely to hear where the noise is coming from? If you lightly press on the boards, does the noise change?
    Pleas upload the pictures of the whole backside of the TV showing all the boards.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4543
      • Italy - Milan
      I think that type of sound usually borns on a coil, it is one from a dc_dc smps or the ones from the audio amp , maybe there is one with the cracked ferrite. But since it is on standby the field is restricted, audio amp cannot be, one one in the standby supply rail.
      • twikii
        • Dec 2019
        • 9
        Thanks for the response! Attached is an image of the full backside of the TV, the main board, and the component that I think is making the noise. Is this a coil? It's a little hard to isolate the noise and tell which component is making it, even when holding a cardboard tube up to my ear, but I'm pretty sure it's that little guy. Tapping on/pressing on the component doesn't seem to change the noise, though sometimes it will have a clicky noise that sounds a little bit like a hard drive.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4543
          • Italy - Milan
          That is not what it is usually called mainboard, that is power supply, the item is a standby supply transformer, it is useful to check for high ripple in the electrolytic capacitors in the area, using an oscilloscope or maybe a frequency meter, or check their esr.
            That transfomer has ferrite core with two half are jointed together, so look real close at the two joints to see if they have a gap or the core is loose.
            The TV functions fine, correct? and nothing change on the screen when it makes clicking sound either, right?
            • twikii
              • Dec 2019
              • 9
              I don't see any gap between the joints, and the core looks good to me. I tried tapping it because I read somewhere that can sometimes help, but it didn't. I'm not sure what you mean by checking for ripple in the capacitors. I borrowed a friend's multimeter and tested some of the components, but I don't really know what I'm doing. Is there something I could safely put on the noisy component to quiet it down? Is the component something I could replace fairly easily by soldering on a new one? Or would it be best/easiest to just replace the whole board?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4543
                • Italy - Milan
                you will not find the right part on sale, this is a custom part, those gaps are usually covered by glue, i suggest you to get a hot glue gun and glue the ferrite around against the pcb.
                • twikii
                  • Dec 2019
                  • 9
                  Thanks for the info! If I am understanding correctly, I should try putting glue around the base of the component - where the red line is?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4543
                    • Italy - Milan
                    yes.
                    • twikii
                      • Dec 2019
                      • 9
                      I put a good amount of glue around the base of the component, but it didn't resolve the issue. Is it ok to put glue on top of it, too?
                      • R_J
                        • 9625
                        Start by replacing the two small electrolytics C7907 and C7918. It could be the noise is caused by the standby ic not operating properly and the waveform is a bit erratic.
                        You could also replace C7303, C7950A & B, the standby output voltage caps
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4543
                          • Italy - Milan
                          Don't waste money/time, if you press a piece of sponge on it when it is working and it makes no changes the the glue is not right, you can take a plier and press very gently the two ferrite halves one against to other, if it doesn't change i guess there's another part that makes the noise.
                          • ChaosLegionnaire
                            by ChaosLegionnaire
                            09-13-2022, 09:02 AM
                          • scubacamper
                            Sharp Aquos LC-70C6400U Half Screen Dark
                            by scubacamper
                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                            05-03-2025, 12:19 PM
                          • Questcom
                            Sharp Aquos 40aj6ke backlight ok, no sound or video
                            by Questcom
                            Hi All,
                            I have recently purchased a faulty Sharp Aquos 40aj6ke which turns on and has backlight but has no sound or video, the person I brought it from told me he had changed the main board and the same fault was there.
                            I have tested voltages on main board and they seems ok, the backlight is at 75v, I believe this tv has 3 x 8 strips of leds which 75v would work out to around 3v per led
                            I think the issue is on the board that attaches to the lcd, doing a bit of digging watching videos etc, there is a lot of mention of vgl and vgh being around -8 and...
                            03-20-2021, 05:55 PM
                          • sefoster
                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                            by sefoster
                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                            11-20-2022, 09:29 AM
                          • jonah1024
                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                            by jonah1024
                            Hello!
                            I'm a few days old into this TV screens repair universe so please bear with me.
                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                            - I did a factory reset as well...
                            07-16-2024, 04:23 AM
