Hi guys, I have a 12V .2A cooling fan that I removed from a computer and I want to add it to this tv whose mainboard was not working as the BGA chip under the heat sink was not making contact anymore. Do I need the fan pulling in air to the heat sink or pushing air out? Should I install it directly to the heat sink or on the back cover of tv? Then finally the fan has three wires how and where do I connect them? I appreciate you guys helping me.
M43-C1 adding cooling fan
Re: M43-C1 adding cooling fan
Did you try hooking up just the fan Black and Red wires to 12V power supply to see if it will spin?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thanks for replying budm... yes I did and it did spin, however I went on and rigged the red and black wires to a USB cable and have it connected to the USB port on the TV. Do you think that will be ok?Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/attach...7&d=1577498150
Hook it up to the switched +12V so the fan should only come on when TV is turned on.Never stop learning
https://www.badcaps.net/forum/attach...3&d=1577512189
It is on the connector CN?101 on the right, you can also see the pin-out chart for that connector.Never stop learning
Since the 12V is not switched on this board then you have to add a switched circuit that will be switched on when PS-ON signal is present.Never stop learning
Your fan is made to run at 12V so does it run if you have only 5V supplied to it?
The pin is labeled as 5V/3.5V so is it really 5V or 3.5V for your board version?Last edited by budm; 12-29-2019, 04:53 PM.Never stop learning
USB is only 5V.
You can look up spec sheet of the fan to see what the min Voltage for the fan to operate.
Is it too loud when running at 12V?Never stop learning
I am sure that there is switched 12V for feeding the T-CON board, but adding the FAN to that switch may over load and also may introduce the electrical noise from the fan into the 12V for running the T-CON.Never stop learning
Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
Securing a good thermal interface between...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:35 AM -
by HondamanI hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
(After previous generation hardware [Gigabyte] didn't...-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by eccerr0rDoes anyone here run an AIO or other liquid cooled CPU cooling solution 24/7/365 / on a server? Do you feel comfortable with possible failures? Should I be worried about pump failures? Pump failures causing leaks?
Having reservations on a second hand cooling system on a PC. So far it's pretty good, keeps things nice and cool but I've never had long term experience with 24/7/365 operation of water cooling, AIO or not. Might have to downgrade to an air cooled system for peace of mind?-
by sam_sam_samThis is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
https://www.eb... - Loading...
