LG 65UH5500-UA Backlight flash on first power up only
    Re: LG 65UH5500-UA Backlight flash on first power up only
    https://www.badcaps.net/forum/attach...1&d=1576726423
    1.2V = Enable PFC only
    2.2V = Enable PFC + HBC
    BTW, If that pin is connected to anything then it should not change state.
    • jason123
      • Oct 2015
      • 1069
      So after several attempts at finding what else that pin 22 is connected to, I took the IC off the board again (hopefully no major damage!) and sure enough, that pin 22 (unless I'm counting incorrectly) is "ONLY" tied to that cap (Used for soft start mode only) - I don't see a way it's connected to an opto / enable function.
      What am I missing?
        OK, I read page 11 and 12, the IC has internal pull-up circuit for pin 22 to start the IC, you then pull it down when you want to disable the IC.
        So basically, this board the PFC/HBC are always running.
        • jason123
          • Oct 2015
          • 1069
          So given that there maybe issues with the main board, I wanted to replace it (since I am vested in this TV - ), but the same part number board (EAX66958003(1.1)) seems to be used also on 50UH5500
          Does anyone know if the 50UH5500 board would work in this 65" TV?
          I couldn't find firmware to flash the main board if needed, or do I need to change something in the service menu?
          • nomoresonys
            • 12206
            • U.S.
            #65
            If that is your board, then your board number is EBR82959601, the other numbers are generic numbers, board gets populated, board gets sticker, the number is on the sticker, minus EBR : https://www.shopjimmy.com/lg-ebr8295...-ua-cusjlh.htm
            • nomoresonys
              • 12206
              • U.S.
              #66
              Now looking at the reference guide here, it does appear that they use the same firmware but I did not see anywhere while looking at boards from various sites where they will interchange: https://www.lg.com/us/support/product/lg-65UH5500.AUSQ
              • jason123
                • Oct 2015
                • 1069
                Thanks... just got the board and it seems to work beautifully.. when i look in Settings it says TV is UH5500...seems all firmware is the same as you stated for the UH5500... Oddly people on ebay are selling the 65UH5500 for higher price than the 50UH5500
                • Diah
                  • Feb 2013
                  • 6380
                  with service remote or apk on android if you use (E-Z adjust) and (IN_Start) you can change the version of size / serial no / and other stuff to match the original info which printed on the back cover of the set... in order to connect correct to LG server update and smart server
                  • nomoresonys
                    • 12206
                    • U.S.
                    #69
                    Glad to hear it worked.
                    • jason123
                      • Oct 2015
                      • 1069
                      Thanks Diah. Nothing seems to need an update. Software is connecting to server and downloads correctly. Thanks
                      • jason123
                        • Oct 2015
                        • 1069
                        I am in disbelief... very glad it worked. Thanks
                        • triplefour
                          TCL 75S421 has sound but no backlight not even a flash
                          by triplefour
                          TCL 75S421
                          PSU BOARD: 40-L402H8-PWD1CG
                          it shows not even a flash of backlight when powering up.
                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                          with mb connected, PSON...
                          11-17-2023, 09:54 PM
                        • Superbee_dad
                          Sharp 80” long short flash backlight error - Help
                          by Superbee_dad
                          Hello Sharp TV experts
                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                          01-24-2025, 11:51 PM
                        • ekozeko333
                          by ekozeko333
                          🧠 What I’ve Done So Far
                          Flashed...
                          06-21-2025, 02:48 AM
                        • corrize
                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                          by corrize
                          Hello, I'm stuck in troubleshooting…
                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                          10-01-2022, 10:02 AM
                        • crozoki
                          Philips 65PUS6554/12 one time backlight flash
                          by crozoki
                          Hello
                          I have Philips 65" TV (65PUS6554/12).
                          Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
                          Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
                          Power board TPV 715G9187-P01-008-001S
                          Main Board 715G9907-M01-B03-005K...
                          09-03-2022, 05:47 AM
