samsung UN46D6450UF - no picture. Test TCON?
  • digitalscorpion
    • Mar 2012
    • 37
    Model: UN46D6450UF
    I'm at a point where i'm attempting to determine failure as TCON or bad panel.
    TCON part#: LJ94-23176E (SH120PMB4SV0.3, LSJ460HW01-S)
    I have tested fuse on tcon (12v) and have tested some voltages at test points near the LVDS input (~1.5-1.8v). I have tested some voltages at the panel flex cable connectors on the tcon (less than 1v on most except for like the last 2 pins ~1.5-1.8v).
    I have also done the flex cable removal to see if the half image shows and there is no change regardless of 1 cable, both cables, zero cables, etc.
    Unfortunately i can't find a schematic (people even use those anymore??) of the TCON board so i'm not sure if my end voltages before the panel are legit.
    Any tips?
    • 12330
    • U.S.
    Re: samsung UN46D6450UF - no picture. Test TCON?
    Test: with tv unplugged from power, unhook cable from powerboard to mainboard, leave unhooked, plug power cord back into powerboard, see if backlights come on and stay on, test is for if you don't have backlights working.
    • digitalscorpion
      • Mar 2012
      • 37
      I didn't do this exact test, but my backlights are functioning properly. I'm getting no video display (no picture, no OSD). Backlights stay on at power up.
        • 12330
        • U.S.
        Ok, wasn't sure if you had backlights, try shining flashlight on screen maybe hit menu button see if you see any text or anything going on.
          Can we get high res straight shot pictures of YOUR T-CON board so we can see the test points?
            • 12330
            • U.S.
            • digitalscorpion
              • Mar 2012
              • 37
              sorry it was faster for me to snag pic from jimmy. So I have voltages coming in and some voltages at test points going into panel flex cables. Just not sure if those voltages are good or what they should even be.
                I see at least these test points:
                VONE =
                VOFFE =
                VCC12 =
                VDDMHL =
                AVDD =
                VIN_12V =
                VCC33 =
                VCC18 =
                Also need the P/N of the LCD bias power supply ICD1 (on the left side of the board)?
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
                  09-07-2024, 05:50 AM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
