lg 60ln5400 power on to lg logo and stuck at a weird screen
  • Jp06
    • May 2016
    • 127
    • Usa
    Happy holidays everyone,
    I have a lg tv (60ln5400) stuck screen issue and hoping that someone could tell me what it is and how to fix it.
    I lost the power cord and remote so i got a replacement cord on amazon. When i plugged it in, the tv came on without having to press the power button. The lg logo appeared and went straight to this screen with the circle at the bottom right and it's stuck there (refer to images please). There are no responses with any buttons from the back of tv.
    I baked the main board at 385F for 10min and have the same results.
    Thank you so much for any helps.
    • 12269
    • U.S.
    Re: lg 60ln5400 power on to lg logo and stuck at a weird screen
    Could be a bad eeprom, that's one of the symptoms.
      • 12269
      • U.S.
      Ic 104, try heating it with a hairdryer or cooling with freeze spray or upside down can of duster, then plug in tv and try it, see if there's any change, even if only for a while.
      • Jp06
        • May 2016
        • 127
        • Usa
        Thanks, I will try that out tonight. I had a feeling that i might need to buy a new main board.
          • 12269
          • U.S.
          Replacement mainboard is probably the best bet, specially if fault can't be pinpointed.
            • 12269
            • U.S.
            Took a look around the net, most say sold out, best I see is there for 110 bux, there is a make offer option also: https://www.ebay.com/itm/LG-60LN5400....c100290.m3507
            • nicholas1110
              • Aug 2012
              • 127
              • usa
              From the picture it appears that it is trying to lower the volume as you can see the - symbol is highlighted red. I suggest unplugging the buttons and see if the fault goes away.
              • Jp06
                • May 2016
                • 127
                • Usa
                I did what Nomoresonys and Nicholas suggested and got no changes. What seems odd is why does it power up right away when I plugged the power in (without having to press the power button). Can a bad ic104 or main board causes that or is it short circuit somewhere?
                  • 12269
                  • U.S.
                  Yes bad eeprom can do that.
                  • Jp06
                    • May 2016
                    • 127
                    • Usa
                    Thanks Nomoresony, I will get a new replacement board.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Most times the main board remembers the state it was in when power was removed. IOW if you could power it off with the remote then unplug the power upon plugging it back in it would return to standby instead of "on". Try it with another TV you have.
                      • Unspun01
                        • Jun 2011
                        • 349
                        I agree.
                        Volume down button is highlighted in red. It appears the button is pressed, or some wire is pinched/shorted and makes the TV think the button is pressed.
                        Did you disconnect the buttons from the wire harness only? or did you disconnect the wire harness from the mainboard. If it is a bad wire, try disconnecting the harness from the mainboard.
                        Could also be a bad de-coupling capacitor or pull-up/pull-down resistor on the volume down input line to the processor. If you can figure out which line is being pulled down, you may be able to force it the other way.
                        You could also try shorting pins 5-6 on the 8-leg SOIC EEPROM/SPIFlash chip when you plug in the TV. This will interrupt communication to and from the EEPROM IC and could allow you to start the TV.
                          • 12269
                          • U.S.
                          For sure shorting pins 5-6 might work, don't cost anything to try.
                          • Stunt
                            Hp Laptop Stuck on Hp protected by hp sure start screen
                            by Stunt
                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                            screen that's it and stuck there. I left it until the following day and i still...
                            09-02-2025, 01:51 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
                          • ahoonid
                            MacBook Pro A1398 L2013 weird jumping screen.
                            by ahoonid
                            Hey everyone.
                            I have a 820-3787-06 board from a MBP A1398 which has a screen issue. The problem starts with a bit of noise just like old TVs when booting and when the OS is on, screen jumps are added to the little noise on the screen. The jumps are millisecond and go back to the original place.
                            Since there's a little crack in the corner of the screen, I thought it has to be the display. But to my surprise it wasn't since I tried it with a fully functioning screen.
                            The same issue isn't happening with an external display. I did a gpu/cpu stress test on external...
                            02-07-2024, 05:56 AM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
