Sharp LC-70LE757U dreaded 2-5 Blink
  • Dustin075
    • Nov 2019
    • 4
    • Usa
    Long time looker first time posting. Little background info on the tv, was looking around Facebook and a free tv came up that didn't work, well I have fixed a few before without issue, picked up said tv and lady told me that the picture was a little fuzzy then it just went out one day now getting the 2-5 blink. So with all the info I have gathered here as got me to this point, on the t-con board there is 4 ribbons, if I unhook all of them I get the backlight, (looking at back of tv) if I unhook the two left ones I get 2-5 light, if I unhook right two (looking at back of tv) tv comes on with a picture on the right and a white screen on the left (looking at tv). So I processed to unhook far left and right ribbons (on edge of tv) unhook left side 2-5 light, unhook right side tv turns on but the picture is pretty bad and fades out as it goes to the left (looking at tv, side that's unhooked). Hopefully all that made some type of sense, so my question is what is my next step, is the t-con board junk or is this just a lost cause and the entire tv is junk? Any info is appreciated.
  • Dustin075
    • Nov 2019
    • 4
    • Usa
    Re: Sharp LC-70LE757U dreaded 2-5 Blink
    Anyone?
    • budwich
      • Jul 2015
      • 3097
      it "sounds like" the "standard bad tab" problem on the side of the panel.... but without some pictures of the display showing what you are seeing... it is just a "good guess". Read up on posts about tab issues on sharps to see what is involved... along with posting some pictures. NOTE. it is likely the set can be saved AND it is UNLIKELY that it is a tcon problem.
        • 12269
        • U.S.
        https://www.badcaps.net/forum/showthread.php?t=49281
        • Dustin075
          • Nov 2019
          • 4
          • Usa
          The half picture is with the left side t-con unhooked (looking at tv)
          The other picture is with the small ribbon on far left side unhooked
          The picture uploaded upside down
          • budwich
            • Jul 2015
            • 3097
            you need to feed in a good signal to ensure that the display is showing "well" before you go to far about dealing with the "side stuff" as sometimes issues with the bottom can exist.
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
            • EazyBone
              Un50cu7000 2 blink oddity *partially solved
              by EazyBone
              I write this to maybe help another with this TV.
              So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
              The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
              03-18-2024, 10:24 PM
            • Mitike
              SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
              by Mitike
              Hello guys,
              I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
              According to other sharp SM-s it is lamp error (I can't find SM for this model)
              And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
              If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
              02-16-2020, 08:11 PM
            • SdlewisSr
              Sharp LC-80LE632U 2-5 blink code
              by SdlewisSr
              I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
              Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
              07-11-2021, 07:36 PM
            • c00lman
              Sharp LC-90LE745U 3 slow and 1 fast Blink
              by c00lman
              hi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
              the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
              did some voltage measurement on the power supply out.
              Pin 1 and 2 = 0V --> PNL 12V
              Pin 3 and 4 = 0 V --> GND
              Pin 5 to 8 = 13V --> UR 13V
              Pin 9 to 12 = 0 V --> GND
              PIN 13...
              06-21-2021, 05:18 PM
