Borads manufacturer's code starting with 715G
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4541
    • Italy - Milan
    Sorry Boards not BORADS...
    Hi, my curiosity, who knows the mistery of the producer of the plenty of boards without brand mark but with codes always starting with 715G? I think is Acer but it's only a guess..
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Borads manufacturer's code starting with 715G
    Chinese unbranded but are used in Philips tvs
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      Not only Philips, i don't think is not branded.
      • William1967
        • Nov 2017
        • 217
        • Netherlands
        Explanation of the code is as follows:
        715Axxxx-Nnn-MMM-OOOO
        715 is the main category.
        Axxxx is the sub category, sequential coding number.
        Nnn is the version code, where N is the development number and nn is the production number.
        MMM Mounting variation code.
        OOOO Optional variation code.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4541
          • Italy - Milan
          You know this but you don't know the Manufacturer?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4541
            • Italy - Milan
            I think i have solved the mistery, them are from Chinese company TPV and this is the proof i think: https://www.tvparcasi.com/715g6973-p...24837-68-B.jpg
            (watch the writing TPV before 715G)
            It is a brand that cooperates with European TP-Vision, part of Philips, and is part of CEC, the China government electronics corp. and, seems, the biggest electronic manufacturer in the world..
            BYE..
              LCD LED TV Service Menu Codes
              TCL LED TV Service Menu Code
              LG LED TV Service Menu Code
              10-31-2024, 03:58 AM
            • SmartSmurf
              T470 not starting - error code 0285
              by SmartSmurf
              My good old T470 out of sudden hung while starting up, unable to power off while pressing the power switch for a minute or so. After 10 minutes I removed the battery.
              Now the BIOS plays the 0285 sound (decoded with diagnosis app).
              The BIOS was not protected by user nor supervisor password.
              I have no flash dump, but I am experienced to dump it. Is it worthwhile? I read that this error can be solved my deleting the ME part of the BIOS.
              Any advise?
              07-09-2023, 04:06 AM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              08-26-2025, 04:42 AM
            • Sorrow1
              Intergraph TDZ 2000 mainboard post code 2F/2E
              by Sorrow1
              I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
              It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
              When I recorded video of POST card and played it in slow...
              01-03-2024, 04:13 AM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
